Old 19th April 2013, 08:01 AM
Default Oops!
Well... I was pootling along just outside Peebles yesterday, about to overtake a van, then a boulder the size of a house (OK, maybe 2 fists) suddenly appeared from underneath it, and as I was a bit over the road... There was a nasty 'thump' and this happened
Old 19th April 2013, 08:11 AM
"oops!" wouldn't have been my response!
Rubbish luck but glad you're OK, Richard. Could have been nasty with an asteriod like that on the llose.
Old 19th April 2013, 08:13 AM
You were lucky nothing worse happened. Is that sort of damage repairable?
Old 19th April 2013, 08:32 AM
Looking at the pics on the powdertec website, they should be able to fix it.. it's got a bulge where the crack is.. Tyre looks OK from the outside (was new a few weeks ago!).
Suspension looks all OK when I had the wheel off and it all drives straight, so a lucky escape I think..
Old 19th April 2013, 08:38 AM
Should be fixable, don't know how much though.
I've got a distorted wheel, probably from a pothole, that my mobile tyre man took off and checked earlier this week. I was getting bad vibration around 50-60mph.
He's referred me to a specialist a few miles away who charge a flat rate of £70 + VAT to reshape and balance "most" normal distorted wheels - more for extreme cases (which mine isn't).
Old 19th April 2013, 09:20 AM
Given a choice I'd bin a wheel that badly damaged - although it can be bashed back into more or less the right shape and welded it will always require serious amounts of balance weights
Worth seeing if you can pick up a couple of spares from somewhere or worst case use it as the spare if you have a full size alloy at the moment
Old 19th April 2013, 11:24 AM
Or if you want to see if A8 Parts have one I could pick it up for you on Sunday
Old 19th April 2013, 12:22 PM
That's an option Brian..
Powdertec did say they'd have to stick it on their balance machine first to see how screwed it is
Old 19th April 2013, 02:56 PM
Friend of mine had big bulge and nasty crack on the edge of rim that he got hitting kerb at decent speed while drifting out of roundabout. He used place near Northampton to repair it. It was £65 all inclusive was done in half a day did not need excessive amount of wheel weights and you could not tell it had been repaired.
