Old 8th July 2009, 05:51 AM
Originally Posted by carrotchomper View Post
Thanks for all the replies. I am 99.9% sure the wheel will physically fit on the column, and Audi seem to suggest same, it's purely the airbag wiring issue I am concerned about.
Which I won't be able to check unless I get hold of one!
At worst, I'm sure I could sell it for £100-odd as a complete unit with airbag to some A4 nut...
Any airbags for a 8eo 41909 1bc 73g lying around Ian?
I dont think you'll have airbag issues - As the Ebay listing says, it comes with the airbag wiring loom anyway, so that will probably match your existing loom as you dont have tiptronic on your existing wheel, and even if it doesnt, hooking it will work I'm sure, these things are very interchangeable....
As for the part number, I'm not sure its the right one? - 8E0 is a prefix for A8 D3 components, and all the A8 wheels have small round airbags, so I doubt very much that you have the correct part number there....
Old 8th July 2009, 07:49 AM
AndrewGray AndrewGray is offline
Originally Posted by CliveH View Post
I wonder if this will fit and wire up OK?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=220448357613
that would be immence if it did!
Old 8th July 2009, 08:02 AM
CliveH's Avatar
CliveH CliveH is offline
Default You can see Ian's response here...
http://forum.a8parts.co.uk/showthread.php?t=1041
Old 8th July 2009, 08:33 AM
carrotchomper carrotchomper is offline
99% sure that is the right part number for the wheel- The wheel is stashed in the car at the moment so I can't check, but that was the number I passed to Audi...
Old 8th July 2009, 12:11 PM
Is this a standard Sport airbag? Looks like broadly the right vintage and I do like the silver ring but it looks a subtly different shape?!
Old 4th August 2009, 08:47 AM
Default It's arrived!
I've got hold of a standard Sport airbag now. Not quite as nice as the one with the metal ring that I missed out on but seems to have broadly the same loom as the wheel.
Assuming I disconnect the battery and follow the instructions, is this really a DIY job? Am a little concerned about the explosive element!
Old 5th August 2009, 09:17 PM
Anyone? Is it easy/safe to do?
Old 5th August 2009, 09:59 PM
CliveH's Avatar
Default Easy job
Yes, it's very easy - just follow Ian's instructions above, although I used a 10mm splined socket for the big bolt which holds the steering wheel in place.
I would also take the precaution of disconnecting the battery, as Ian suggests.
Old 6th August 2009, 11:26 AM
Thanks! Just need to get myself down to Hellfrauds to pick up a suitable socket/Torx set.
Old 6th August 2009, 11:35 AM
CliveH's Avatar
Default Tools
Halfords do complete sets of Torx and splined sockets. Not cheap, but good quality. They sell the Torx sockets separately (about £4 each), but I think the splined ones only come in sets, which are about £22. Might be worth shopping around.
