Old 30th May 2013, 06:57 AM
I wonder if there is capacity in the seat memory module for those wires. I can snake those 3 wires anywhere in the car, the question is if I approach memory seat ECU with those wires will it have 3 empty terminals for passenger belt rheostat? I studied wiring diagrams I didn't find those 3 wires.
Where is seat memory ECU located by the way?
Sorry, I'd read your post the wrong way round - so you have memory seatbelt, but no memory wires on car loom.......
Unless all seatbelt motos have memory, and passenger seat memory was designed to not have seatbelt memory, but I am away from home and just guessing.....
Seat Memory module is under front of seat, your will see it I think if you tilt front of seat up and look under. It has many connections. I would be surprised if they had made different memory module for passenger seat without connector, so would expect pins to be there...
Silly question. Have you read the handbook - they are usually pretty accurate, does it say passenger seatbelt should be on the memory ?
And if you have factory passenger seat memory, the drivers side module should be 1,2,3,* not 1,2,3,4. Is this the case ?
