Old 3rd June 2013, 06:48 PM
Jake242's Avatar
Jake242 Jake242 is offline
Default Bose upgrade?
Hi guys, just bought a complete Bose system from a 1997 D2. Would that be possible to fit to my 1994 D2?
I'm hoping its basically just a swap of exsisting speakers, and amp(using same wires)... But is there more to it?
As of now I am running a pioneer HU on the standard system and it works great actually... But since I found out my car was never fitted with Bose... I wanted it
Paid roughly £110 for the whole thing... Delivered to my door from Germany.
Hoping for some answers
Cheers, Jake
Audi A8 4.2 quattro D2 94' - THE CARRIAGE
Audi A4 1.6 B5 95' - THE LADY IN RED
Opel Kadett 1,2 C 77' - THE CASKET
Old 4th June 2013, 06:25 AM
from memory, a lot of the PF cars had full looms from the factory from new so if that is the case then all the connections and wiring should be there, you just need to get hold of the PF wiring diagram and then find it all!
Old 4th June 2013, 07:34 AM
As stated us early 8's have a pre wired car so just plug it all in.
The speaker cables will be the same anyway, amp to go in and speakers oh and head unit.
Old 4th June 2013, 11:33 AM
Jake242's Avatar
Thats a perfect answer Dezzy(the one I was hoping for)
Cheers, Jake
Old 4th June 2013, 06:34 PM
...... but, the wrong one sadly ......
The Audio loom is a seperate, bespoke bit of loom and was customised for bose / non bose etc, even on early PF. The wiring route around the car is fundamentally different for the two.
Non bose has no amp, the front speakers are all driven off the head unit directly, and the rear parcel shelf speakers have mini amps that amplify a line input they have, and they provide juice for the rear doors too.
There are no wires anywhere in the boot area for speakers, and in particular nothing there for the Bose amp.
The bose wiring is notably thicker too.
Sorry, this aint going to be plug and play, but saved you the confusion of trying to figure out why the heck it aint fitting....
a8parts may well be able to supply you a full bose wiring loom, but its still very much a whole interior out job to fit. Last time I did one, it took 12 hours end to end, with 2 people.
It's doable for sure, but you gotta really want it
Old 4th June 2013, 09:53 PM
Jake242's Avatar
Huh... Non bose has no amp? I have an amp??? Its on the opposite side of the battery?
Maybe I have bose already? Thought they were identified by the bose logo on the rear speakers(which is lacking on mine)
But I defo have an amp...
Cheers, Jake
Old 5th June 2013, 06:21 AM
I'll get my coat
Old 5th June 2013, 08:17 AM
I think the PF only had Bose stickers on the woofers if at all.
The standard unit will come up and say 'Bose' when powered on if it's equipped. (You still got it to drop in?)
Old 5th June 2013, 08:28 AM
Jake242's Avatar
Sadly it has never had the original hu installed while I have had the car.
Would the amp say bose?(with a sticker or something)
Cheers, Jake
Old 5th June 2013, 08:37 AM
Post a picture, they're quite distinctive.
My PF had Bose stickers on the woofers and no other indication at all, not even on the RNS-C at power-on IIRC.
Though I do think Bose cars have a different (2 fewer?) number of speakers, just dummy grilles where they are missing.
