As far as I can tell it will be the one on the radiator (condenser) at the front of the car.
I will try and post a picture - it is the silver and black item half way down on the left : http://images.a8parts.co.uk/parts/2135.jpg
At Work to Break: 2001 TT 8N 1.8T Quattro with a loud exhaust! 2000 A8 D2 3.7Q Non Sport Ming Blue 1999 A8 D2 4.2Q Non Sport Santorin Blue 2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather 2001 A2 1.4 TDi 2006 A6 C6 2.4 Quattro Avant Canyon Red At Work to Drive: 1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch 1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash 2008 Fiesta Sportvan x2 2002 Transit 2.4 LWB 2007 VW Crafter Recovery Truck 2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart 2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses. At Work to Hire: 4x 6 Berth Sunlight Motorhomes |
Yeah, item 4 in pic. Note part number isn't current - been superceded
Would anyone have the correct colour sequence for the Air Con pressure sensor of this car please... I've just bought a sensor and connector with wires attached, however Audi supplied them all being yellow and the wiring diagrams available don't show which colours 1) Brown 2) red and white 3) yellow and white. Go with regards to the top to bottom of the sensor. Anyone who can show an image or a wiring diagram of the correct sequence will be of the most help ever.
Regards Mark
Registration: 2 WXG (Private plate from 1962 Model: MY 2008 08 3.0TDI Quattro Sport, Black on Black (Transporter Edition) Lowered 60mm on drop link bars. Alloys swapped out to RS6 style 20" x 9.5". It's got full tints on all windows, and has the black leather interior. Remapped by Elite Automotive in Cornwall, giving an increase output to 290bhp/450lbs. Options: Keyless Entry & Start, Bluetooth Hands Free, Quad Zone Climate, 3 Spoke Sports Tiptronic Multi Function Steering Wheel, Black Leather Comfort Seats, AMI, Drivers & Passenger Electric Memory Seats, Auto Dimming Mirrors, Bi-Xenons. Future Plans: Selling my current Audi A8 Quattro Sport and replace is with a newer D4 Audi A8L with the 4.2V8 Twin Turbo setup once again it must be black. I'm looking for one with the options added where it has the rear recliing seats, with heated outers. Bose speakers minimum and B&O's if affordable. Rear and back door sun blinds prefered. Planned Mods: Upon the arrival of my A8L D4, I will be once again having the ECU remapped to a performance setting over economy. Rear Tints as dark as can go whilst also tinting the front windows with a medium tint. Once again I will be purchasing lowering links for the air ride suspension and setting it at 55mm lower when in comfort as my desire rideheight over standard. Alloys will be 21" however the one current most likly to be the next car already has a brand new set of 2016 S8Plus wheels on it. My Business: "The Transporter - Cornwall" find us on Facebook or download the Smart phone application by clicking the link below. http://TheTransporter.appsme.com |
I think this may help... you can see the sensor on the middle right of the radiator
Previously: 2010 Audi A8 4E Quattro Sport TDI Oyster Grey Currently: 2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey |
Had one of these fail on my A4 (2006) just before I sold it to buy my A8.
You should find if the pressure sensor has faulted out then they should typically go short to ground as they break up. The plastic body on the back of the sensor goes brittle and breaks up, alloys moisture ingress and they die a slow painful death. You should see that when it fails the car will default to 'eco' / 'econ' mode to stop the compressor engaging and it won't let you turn eco mode off so have a look in mmi see if it's doing that. If the sensor has gone faulty it'll tell you via a fault code too. If you do change the sensor make sure you get a good spanner on the pipe before you try to remove the sensor from it. The pipes are aluminium and crazy crazy soft and will twist up so easily you don't want to risk rupturing it. If it does leak it's very illegal and worse still mad carcinogenic heavy gas so get the hell away from it if it goes.
Current: 2004 D3 4.0 TDI V8 in Crystal Blue. Factory: finger print, tv, xenons, keyless entry & go, soft close boot, 19s, and probably lots more besides Done: fixed headlight washer leak, fit Bluetooth in place of factory phone To do: DAB, DTV, fix soft close boot, get a spare key, investigate NSF bushes, |
Hi so what does this mean I had the garage replace the sensor but this fault is still there would it be a duff sensor.1 Fault Found: 00819 - High Pressure Sensor (G65) 010 - Open or Short to Plus cheers trev. |
The cars store the fault codes unless you tell it to clear them; if you get the full fault code log it should give you the date, time and tell you if it's still detected or not. It's unlikely the new sensor is duff, that'd be pretty harsh luck if it is; chances are the fault code just needs clearing. If you have the necessary tools to do so clear the code and see if it comes back or not.
