Old 13th June 2013, 10:00 PM
Don't forget that a lower noise tyre will often mean a softer compound and therefore shorter lifespan. It's all a trade off in terms of requirements
Old 13th June 2013, 10:04 PM
rs32 rs32 is offline
yep Asym (V1) on an R32 with RS6 brakes and "well-used" lasted me 16k
Old 13th June 2013, 10:35 PM
Christ you did well - my V2s lasted 9k on the A6!
Still got Asym V1s on our Citroen BX 16V but that's so light it doesn't worry the sidewalls with extra weight on turn in! They're been on the car for years but it does so few miles I suspect they'll be binned for age reasons eventually
Old 13th June 2013, 11:01 PM
Michelin PS2s or Super Sports for me - both have good grip to the limit (the latter are better), have very good wear, and aren't too noisy. In practice, they also provide some limited rim protection, but this isn't as good as some other tyres with a more visible ridge.
I fitted supersports to the RS6, a bit too lively in the wet, but I was pushing over two D2 S8's worth of torque through them. The grip is unreal in the dry.
Old 14th June 2013, 08:40 AM
Agreed Amar, and I think your limit in the RS6 is probably a bit higher than mine in the S8....
Old 14th June 2013, 09:03 AM
Zip's Avatar
Zip Zip is offline
Using Vredestein Ultrac Sessanta at the moment. Very happy with them. Wearing well, quiet, very good in the wet. Ran them on a tuned Saab 900 Aero as well - excellent on a powerful FWD car. Eagles very good, not quite so quiet, astonishingly good in the wet, The P Zeros I found unbelievably noisy on 20s. Ran 2 sets of PS2s on 20s and very happy with those, although were getting expensive when I last changed. Not noticeably better than the Vredesteins.
Zip
Old 14th June 2013, 09:40 AM
Zip
Ditto the Vredsteins. Quiet, seem to be wearing well and quiet. And not too pricey.
Old 14th June 2013, 12:23 PM
Norretal's Avatar
Norretal Norretal is offline
Another thumbs up here for the Vredesteins, had them on a couple of months now and give amazing grip compared to other tyres I've had on my A8. I realise it's also due to the fact that they're 275/25/20's and I've only ever had 18's on but I can't find fault with them at the moment, and wear seems to be good so far. The road noise varies but I think that's more a combination of the varying standards of road surface and the unique tyre pattern than the tyres themselves being generally noisy.
And at £150+ less for a set of four than other big brands mentioned I'd say they're good value. I took my recommendation from Amar, he knows his tyres.
Audi TT - 2015 - Ultra
Old 14th June 2013, 12:26 PM
local tyre fitters that I use coming up best for Asym 2's at the moment, they've done about 6 sets for me in the last 3-4 years on various cars and I can't find any of the national companies offering better atm
Amar - know anyone else other than Southam Tyres that can beat £850 fitted for 245/40/19 ?
Old 14th June 2013, 01:18 PM
Yes, Camskill. But they don't have them in stock (£725.80 if they did + £11 postage). They do have, Michelin PS2's, however, which are just as good if not better for £788.36 delivered. That will give you £60 to arrange to have them fitted by your local tyre place. Call Camskill and see when they can get the Goodies for, personally, I’d go for the PS2’s and use the £60 to have them done locally.
