View Poll Results: Shall I?
Yes, it will look and feel superb! 10 66.67%
NO! It's got flappy paddles, FLAPPY PADDLES...!! 1 6.67%
Undecided 4 26.67%
Voters: 15. You may not vote on this poll
Old 7th July 2009, 09:38 PM
CliveH's Avatar
CliveH CliveH is offline
Default R8 steering wheel?
One for sale here : http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=220448357613
Yes Ian, I know I said I had absolutely no plans for modifying the S8, but...just wondering...
Old 7th July 2009, 10:20 PM
I'm actually undecided. I think the airbag may look out of place. But go on so we can all see
Old 8th July 2009, 05:55 AM
It *might* work..
On the D2, the multifunction wheels with tiptronic ran all the tiptronic and button signals down a single wire data bus to a dedicated controller that then put the signals out to the canbus, TCU etc.
If the same control signals are used D2/D3 then I'd see no reason why it would work. Yes, I know this is a TT/R8 wheel not a D3 one, but I'm willing to bet that like on the D2/C5 etc of the time, that all steering wheels would be wholly interchangeable.
I dont have a D2 with multifunc capability right now, or I could have popped a steering wheel off a D3 on to test....
Old 8th July 2009, 08:05 AM
CliveH's Avatar
Default I'm undecided too...
just wanted to see what you guys thought though
For me, any mods that I do to the S8 have to be both tasteful and in keeping with the original styling of the car.
Although this wheel is from an 8, it's from a "sports car" and is the next generation, which is why I'm undecided from an aesthetic point of view. Very tempting though...
oh, and it has to work too! so, thanks for your thoughts on the functionality front, Ian
Old 9th July 2009, 09:56 AM
CliveH's Avatar
Default Any more views on this one please?
before I dive in as guinea pig...
(Note to mods - this probably more correctly belongs in "Interior Trims" rather than Electrics? )
Old 9th July 2009, 12:04 PM
That would looks amazing in the S8. Just added it to my mods when I win the lottery list
Old 10th July 2009, 09:49 AM
ulfilias ulfilias is offline
Hi There,
I have a 2000 S8, D2 - Has a tiptronic steering wheel, but not multifunction alas. I thought it a lost cause, but if Ian says above it is all run down the same wire....could a multifunction one work on mine then ???
I'd also love this wheel !
Ta,
Lee
Old 10th July 2009, 09:53 AM
Hi There,
Looks like there are more complications with this wheel than thought
http://www.audiforum.us/sale/8413-fs...el-airbag.html
It has a dual stage airbag....Not good with a single stage controler and i somehow doubt the D2 has a dual stage ????
cya,
Lee
Old 10th July 2009, 10:06 AM
Originally Posted by ulfilias View Post
Hi There,
Ta,
Lee
Oddly enough, if you only have tiptronic, then there were enough wires on the slip ring for the connections to run straight through, so you will have direct connections for horn, airbag, ground, illumination (for the buttons) and for the tiptronic up/down and these will go straight to the TCU.
On the D2 multifunction wheel, they didn't have enough pins to work with, so the horn and airbag still wire straight through, but the tiptronic and illumination lines were 'stolen' to create a databus instead through which they send everything....
Interesting point on airbags you make, that may well be a show stopper for fitting anything too new, like the TT MkII wheel... Shame... !
Old 10th July 2009, 10:18 AM
CliveH's Avatar
bummer!
