Old 24th June 2013, 03:42 PM
S4_Sat S4_Sat is offline
Default Gearbox speed sensor
Any ideas on where this is? Need to replace it as the speedo isn't working all the time.
Old 25th June 2013, 10:50 AM
Anyone?
Old 25th June 2013, 10:56 AM
I think a lot of the gurus are away - the forum is pretty quiet. Try a PM to Goran and Adrian
Old 25th June 2013, 10:57 AM
rs32 rs32 is offline
does this help ? http://www.audipages.com/Tech_Articl...vereplace.html
Old 25th June 2013, 11:02 AM
What fault does it throw up and does it give a sensor reference?
I'm trying to sort out stuff for our holiday so a bit time short but if its definitely attached to the gearbox I should be able to find a PDF of the location and potential part number
Old 25th June 2013, 07:36 PM
Nollywood's Avatar
It's on the transmission, passenger's side, just above and slightly ahead of the axle output shaft.
Old 25th June 2013, 08:23 PM
on that link I posted above..... 6 is the wheel speed sensor and 7 is the engine speed sensor
