Old 5th July 2013, 07:21 AM
Just one thing: When you remove the cluster put towel/blanket on top of steering column. This will guarantee you will never scratch top of steering column as plastic there is vulnerable and edges of cluster are sharp.
Cluster is removed by undoing two screws under plastic covers on the front and then by carefully disconnecting 3 electrical connection from behind. You will have to do it blindly, with your hand behind cluster, but it will work. You may need to cut a couple of cable tires if you do it for the first time.
When cluster is on the bench/table you know what to do
