Old 7th June 2013, 02:27 PM
Mattyb Mattyb is offline
Default Finally got my car on vcds
Hi all. After a few months of intermittent fault iv finally managed to get the a8 on to vcds what iv got is
17935
P1545 002
Throttle valve controller.
Im guessing this means i need a new throttle body. But if someone can confirm this ill get it ordered asap
Thanks for looking
Old 7th June 2013, 05:52 PM
cerips cerips is offline
From the Ross Tech wiki
http://wiki.ross-tech.com/wiki/index...3/P1545/005445
17953/P1545/005445 - Throttle Valve Controller: Malfunction
Possible Symptoms
Increased Idle Speed
Bucking at Load Change
Possible Causes
Throttle Body dirty
Throttle Body Wiring faulty
Throttle Body faulty
Possible Solutions
Clean Throttle Body
Check Throttle Body Wiring
Check Throttle Body
Old 8th June 2013, 09:13 AM
Nice one dude, thans gona check t out on su day. Its getting on my nerves now.
Thanks
Old 10th June 2013, 05:15 PM
Anyone know what i should be checking the throttle body for and what to check the wiring for.
Matty
Old 10th June 2013, 09:48 PM
Here is some info from ElsaWin which may help
File Type: doc Checking electronic engine power control.doc (78.5 KB, 530 views)
Old 10th July 2013, 10:07 AM
thanks goran, iv fitted two refurbished inlet manifolds and a new throttle body and the problem is sorted, thank god.
