If you haven't already I'd look at getting some braided flexi hoses while they're off. You can clamp the old flexi with some cardboard and mole grips to stop all the fluid escaping but you'll prob want to do a full fluid change or at least a proper front brake bleed after they're reinstalled anyway
Seen any suppliers for braided lines? Would be nice...
Those rubber pipes don't look fleixible enough for my brake pipe clamps....sure they will be. Very jittery about undoing that flare nut...you're right: the pipe wants to turn with it. I'll soak in some WD for a while. Thanks all, Zip
2002 D2 S8: Ebony Black over Platinum. A8L Comfort front seats in black ( ![]() ![]() 2005 B6 S4 Cabriolet: Ebony Black Pearl over Silver. RNS-E, Bose, heated seats, cruise control, retrofit aux-in, centre armrest, Milltek resonated exhaust |
![]() I did end up borrowing a friends brake pipe tool to remake one of the pipes but it was a copper one not the flexi.
They're out! All quite straight forward in the end. Ended up with a couple of fingers off a silicone glove secured with a nice tight O-ring over the end of each pipe to stop weeping. I've got a Gunson Eazibleed which I have used a few times for reassembly time.
Unfortunately the end of the section of metal pipe from calliper to bracket moved slightly at the bracket end when I was removing it, and there appears to be a very small weep....hmmmm. Will have another look when I give everything a good clean later in the week. If you're lucky, you may get a photo of the finished articles when I get them back. Got all new disc and pads all round to fit at the weekend (used Murray's Direct in Hatfield - nice bloke). Meanwhile, spot the missing part... I tell you what, trying to relocate a wheel and disc with no calliper in place ain't easy in this heat.... ![]() Thanks gents. Zip
Missing part hmmm well........ wheel centre cap and wheel cleaner ![]() Do you not have the plastic wheel centring doodar tool in the boot? makes lining up the disc / hub and getting the wheel on a breeze can be found on ebay and you can even get ally ones
Ah yes - forgot about that plastic widget. More trouble than they're worth most of the time.
Yep - managed to get them boxed and off to Nottingham for refurb next day delivery this afternoon as well. Not too much brake fluid and dust on the drive (don't tell the wife... ![]() I've had 4 years of "black chrome with a healthy layer of brake dust". Thinking of going back to diamond cut with some alloygators for protection....love the original finish, but know how impractical they are. Oh well. Zip
Murrays are good, aren't they? I got Meyle HD rear discs and Bosch pads for mine from Murrays recently - is that what they've supplied you too?
Any luck with braided hoses?
