Old 17th July 2013, 02:19 PM
No apparent damage (I havent stuck my head under yet to establish that!) but the wheel is spinning freely on the hub. Need to take the car out now for a drive. I do have axle stands but they are too tall for this car and I have never worked out where they should go on the 8 anyway when the jack is in the way of the jacking pad point(s)
Old 17th July 2013, 02:56 PM
Don't do that without an axle stand!
I'll point out the areas that I use tonight before the BBQ. I also tend to throw an old tyre under the sills just in case
Old 17th July 2013, 03:12 PM
Even with my trolley jack, I still slide the wheel I've taken off under the sill.. Just in case.
The D3 jack seems to be a much better design.
Old 17th July 2013, 03:17 PM
Glad you're ok David could have been nasty. I've had mine off the jack as well and it's not nice is it?
You might have seen this when i posted it but this is what i made to go in the boot for use in the event of a flat after i had my problems.
Jack
I reckon your disc will be alright.
Axle stands can go under the subframe mount for safety.
David the CREW are ready here with pitch forks and zimmer frames, if you need them to take this issue to Audi direct thery're ready to go.
And BBQ eh? Don't seem to have an invite for that one, must have missed it.
Old 17th July 2013, 03:23 PM
Jack
Yes, i saw your post this afternoon when looking at previous issues with this piece of crap. The problem with my axle stands is that the car needs to be so much higher than the normal jack goes to get them under the sub-frame. Perhaps I need smaller stands? I'll check with The Laird tonight. He has also got a heavy duty jack so he tells me (presumably for the armoured version of the 8). He also has a "spare" normal jack if I want it......
Old 17th July 2013, 03:32 PM
Keep the old jack David and i'll make up a "man's" jack with the parts and you can have that.
Have you got any breeze blocks or hard wood blocks lying around?
I use a trolly jack at home, that'll get the car high enough for support under.
Old 17th July 2013, 04:20 PM
Thats a kind offer mate.
Plenty of wood though - that's how I managed to lever the car up enough to get the trolley jack in!
A trolley jack was on my tools wish list. Its now at the top. SWMBO also said I can have a garage with a flat floor and a pit! Not sure that'll I'll swing a two poster lift though!
Old 17th July 2013, 04:21 PM
Though..On a related 'jack of death' story.. the Mk1 Mondeo had a similar jack, and if I hadn't been wearing a chunky wedding ring, I'd have had a fairly messed up hand when it fell backwards off the jack while I was putting the new wheel on. Trapping my fingers between the tyre and the arch, managed to slide the fingers out to see the car sitting with the ring between the arch and tyre, even managed to get the ring back in one piece when the RAC guy finally turned up.
So marriage isn't that bad after all lol.
Old 17th July 2013, 04:51 PM
I also have a spare jack similar to the one Dezzy used to bolt the head off the A8 jack to, so if' you'd rather have one like that, David, you're welcome to it - I almost threw it out in the great garage clear out!
Old 18th July 2013, 06:42 AM
Hey just looking at your photo's there David and that jack that folded on you is different than mine, are the jacking points different on the FL than PF or that jack you have is from an A4. The jacking point has some steel in it and the locator on the jack has a magnet so it's easier to keep it in the jacking point. Not that it makes much difference as the 8 ones fold aswell, but i don't think that's the jack for the car.
The reason i used the SAAB jack was the 9000 is similar in weight to the 8 and it has a flat surface on top for bolting your locator to, i did have another but i think it came from an Astra so didn't thnk it would be up to it. Just be careful brothers, don't make the same mistake Audi did.
Had a quick look on ebay and there are a couple of 9000 jacks for sale, also scissor type jacks with a 1.5 ton rating but same problem with modifing it to suit the cars jacking point.
ID:	6402   Click image for larger version
