Old 21st July 2013, 09:22 PM
Interestingly today it was behaving somewhat better.
Just a little update after having the car for about 6 months now.
I use the cruise control regularly and it now works about 98% with no further "abuse" required.
I think the previous owner(s) probably never did use it and as a result the switches were corroded/dirty. Regular use has presumably cleaned them up.
All functions now work 100% except the "increase" slider and "ignition resets" are never required now.
The "increase" function generally works as it should but just occasionally using it will turn off the cruise function, including forgetting the set speed.
But as Adrian E pointed out it's hardly difficult to use your right foot then press "set", which works 100% nowadays.
