Old 3rd August 2013, 06:36 PM
RallyQuattro RallyQuattro is offline
Default Speed signal from abs or cruise control? to my RS8 biturbo ecu
I have an Audi S8 -97 manual with RS6 engine but I have a fault code (16885) in the RS6 ecu that it is missing a speed signal.
So were can I find a speed signal in Audi A8/S8 94-99 ?
The cruise control must have this? but i don't know cable colour or where I can find this cable in my car?
Maybe also the ABS or clima have a speed signal?
And perhaps it is an speed signal output on the instrument cluster does anyone know this?
Owns at the moment:
S8-97 biturbo = RS8 My new trackday car
A8-94, A8-96, A6 1.8tq -2004
2 Urquattro 20v-90 one red, one blue,
and one old Urquattro ex rallycar,
and some other cars..
Old 4th August 2013, 05:55 PM
There are a couple of speed signals input to the ecu. Abs Sensors at each wheel and output shaft on the transmission. There are also a couple of engine speed signals, input shaft, cam position and fly wheel hall sender. The ecu uses all of the for different functions.
Old 5th August 2013, 08:29 AM
But the question is where are these cables in my car?
My cruise control does not work anymore because it's electricity gas throttle on the RS6 engine so therefore I can take the cable that goes to the cruise control and link it to my RS6 ecu,
but where can I find the ecu to the cruise control and which cable is what I should be looking for?
Anyone have a diagram of the wires to the cruise control ecu ?
Owns at the moment:
Old 5th August 2013, 08:35 AM
The cruise control in that era S8 is a separate module which I presume operates a servo (vacuum driven?) of some sort as the throttle pedal physically moves. It is optional.
Later models are fly-by-wire and the cruise function is integrated into the engine ECU so you "just" need to add the stalk/switches.
What vintage of engine ECU are you using and is it designed to work with a separate servo cruise control, or are you trying to bypass that?
Old 5th August 2013, 08:43 AM
I don't want my cruisecontrol to work!
I only wan't to get a (km/h and mph) speed signal from any cable in my Audi S8-97
I have an RS6 BCY engine with RS6 ecu and this ecu is missing a speed signal = I have a fault code (16885=speed signal) in the RS6 ecu and my tuning company that will remap it for 500hp+ want me first to fix this cable to my ecu so I get rid of this fault code..
Owns at the moment:
Old 5th August 2013, 09:51 AM
Vehicle speed reading on 1997 8 is generated from speed sensor on gearbox output and processed in instrument cluster which then passes processed speed signal to ECU, ABS, cruise control, gearbox, radio, climate control, servotronic steering, satnav , ect.
Old 5th August 2013, 10:05 AM
Do you have any idea where I can find one of these cables?
Owns at the moment:
Old 5th August 2013, 10:18 AM
Looks like signal comes in the instrument cluster on pin 24 on the red connector and goes out the same connector:
ECU pin 19
gearbox pin 9
ABS pin 13
and pin 23 for everything else ( radio, climate control, servotronic, cruise control.etc)
Old 5th August 2013, 09:28 PM
If you want it easy there is always the GALA feed on the back of the Audio unit. It should be clearly marked on the radio......
Its not as frequent a pulse as the ABS generated ones though iirc, but might do depending on what you need, its designed to alter the volume of the radio as speed changes to compensate for road noise etc.
Old 6th August 2013, 07:16 AM
ECU pin 19
gearbox pin 9
ABS pin 13
Perfect
On my red contacts I have these colors:
Pin 19 green / white
Pin 23 White / Blue
Pin 24 yellow / white
So now I just have to find out where these wires go.
I will start to look for 19 and 23
Owns at the moment:
