Old 5th August 2013, 09:30 AM
Dave McB Dave McB is offline
Default Delimited?
I understand its a bit of a pain to get a d2 S8 delimited
anyuone had it done yet, can you manage it with VAGcom or alternatively, where can i get it done?
Old 5th August 2013, 09:41 AM
My old PF S8 was delimited by the owner before me.
It involved replacing a chip, so programming AND soldering.
I even inherited (and hopefully passed on) the actual chip that was removed!
Old 5th August 2013, 10:13 AM
Depends if it is PF or FL. Either way the software in the ECU should be modified it's just that in FL it can be done through OBD but on PF soldering job only. Or just cut the speed signal wire from instrument cluster
Old 5th August 2013, 11:56 AM
I wouldnt get too excited.... It takes a heck of a lot of flat tarmac to get the S8 to 155mph, unless you're a regular autobahn stormer or have your own private airstrip I think it would be a complete waste of time tbh.....
Old 5th August 2013, 02:20 PM
its an 02 so its FL model.
Reason for enquiring was that, having been on the Autobahns & the Nurburgring earlier this year, i fancied going back.
My old S8 would be a great car for making the trip.
Working in the motor trade means that iv got access to plenty of diagnostic software, and wondered if it had to be VAGCOM or if any decent quality diagnostic computers can do the job.
I had also wondered which option to go into to remove the TV-in-motion restrictions
Old 5th August 2013, 04:52 PM
Reffro Reffro is offline
Or do like me and a couple others did and get the Revo map put on it. That removes the limiter at the same time. I had a GPS measured 158mph out of my S8 and it was still pulling hard enough to convince me 170mph was possible.
Old 5th August 2013, 05:44 PM
Really? - I didn't know that, though I must admit i've not tested it at that speed . I tend to agree with Ian really, but good to know, should the need arise
Old 6th August 2013, 10:12 AM
Yes really, on the Autobahn coming back from the Nurburgring 2 years ago. Took surprisingly little time to get there, but does need a lot of distance as you covering a mile every 25 secs or so at the speed. 158mph measured from the sat nav GPS, the car speedo was indicating near 165mph. The speed was still steadily rising, no way near topping out, but traffic prevented me from safely going any quicker.
Old 6th August 2013, 01:27 PM
Norretal's Avatar
Norretal Norretal is offline
I've seen my standard PF A8 show 160mph on a stretch of dual carriageway at four in the morning, and it still felt like it had more to give........exhilarating indeed! Not sure of the speedo accuracy but it was on standard 18's at the time. The thing I remebember most is that despite the speed the wind noise / buffering was more prominent than engine or tyre noise so Audi's sound-proofing and glazing on the A8 really is exceptional in my book
Audi TT - 2015 - Ultra
Old 6th August 2013, 03:54 PM
darrenjoe90's Avatar
I might just have a little blast in the next few days as i have just had a re-map done and speed limiter removed and i will be in Germany
Audi S8 Phantom Black
