Go Back   A8 Parts Forum > General Natter > House and Home DIY
House and Home DIY Everything at home. Building, Renovating, DIY, green initiatives, mowing the lawn. Anything goes
Old 11th February 2012, 09:07 PM
Haha now that i like, also FYI i am also using 1000liter ibc tanks for rain water Snap
Old 12th February 2012, 09:26 AM
Yeah, the IBC's are soooo cheap. the 1000's even cheaper, but I couldnt quite fit them in the garage, so had to pay a little more for the newer 820's.
Still, way cheaper than pukka rainwater tanks...
Old 15th July 2012, 08:14 AM
Ian,
Have you moved to renovated house? I wonder if you're happy with internal wall insulation.
Looking at your photos I see 'aluminium' foil on top of insulation material, which makes walls non-permeable for internal moisture.
No problems of with excessive moisture in the house?
Old 15th July 2012, 09:23 AM
Ian,
He wouldnt have a problem with that, hes got a heat recovery ventilation system that changes the air every 2 hours so moisture is extracted / condensed away and the air replaced with air from outside with a lower moisture content
Old 15th July 2012, 08:18 PM
roboblob roboblob is offline
Don't you mean higher content with Englands new weather pattern
On a serious note, has anyone else noticed the Jet Stream is being pulled towards the Hadron Collider ??
Check out the BBC site for the new path vs the old path and then check where that Hadron doodah is located
Old 15th July 2012, 10:48 PM
Yup, no moisture here... House is sealed tight. No gaps, no trickle vents, all joints taped and sealed......
Air continously exchanged, and any moisture that comes out is recycled into the rainwater tanks...
Old 21st September 2012, 12:11 AM
Baryonyx's Avatar
Baryonyx Baryonyx is offline
That sounds like a hell of a project!
I started on a smaller scale project this year. Hence why I was driving an Impreza GX for most of the year! Three bedroom semi-detached house in the countryside, purchased by me and the missus and with the help of our family (mainly my tireless father), we've stripped it back to the beams, brick and concrete and rebuilt it from there.
It's a complete transformation inside. Literally, hundreds if not thousands of man hours poured into the project. Blood, sweat and tears and sacks of broken horse hair and lime plaster. All the best getting your place sorted, this sort of thing is truly a labour of love with a hint of madness...
Old 13th August 2013, 05:08 PM
Default Epic
This gets the geek in me all excited, love all that stuff, don't understand why new builds are not like that from the get go tbh.
I have been renovating my gaff too and cabled the whole house for Internet, tv and CCTV distro etc its defo the way forward.
Respect for the effort you've put in
