Old 23rd August 2013, 03:01 PM
tomo9700 tomo9700 is offline
Thanks for that. Like you say 2 hours labour plus the seal it cant be more than £150 really? What do most places charge per hour i have no idea.
Old 23rd August 2013, 03:17 PM
Depends entirely on where you live and if it's a local garage or main dealer - anything from £40-140 an hour!
Old 23rd August 2013, 03:29 PM
You do really need someone who is familiar with the construction of the car.
I think I'm paying about £60/hr plus VAT for labour and they're a VAG specialist with all the tools and knowledge.
Old 23rd August 2013, 03:36 PM
Im a mechanic my self but i work on trucks and its fleet only so we dont deal with the public/prices. Id do it my self but with it being on the drive and not at work i really cant be arsed! id rather pay the £150+ for someone else to deal with the hassle locally.
Old 23rd August 2013, 06:32 PM
Be careful, the new seal has a lip, and requires the new type flange with a groove to accept the lipped seal. This was re-designed in recogniton that the old design was too prone to leaking.
I dont know if you can still get the old type seals. From my experience I went to a place that didnt know, and they stuffed the new-type seal into the old flange, which obviously deformed the seal. Needles to say it was leaking again within a year or so. Next time round I went to 4Rings in Dartford and they put in the new type output flange as well, which costs around £120.
This:
http://forums.quattroworld.com/a8/msgs/32544.phtml
and this
http://forums.quattroworld.com/a8/msgs/56848.phtml
Old 23rd August 2013, 07:31 PM
This:
and this
Very helpfull. Cheers
Old 23rd August 2013, 08:28 PM
green A8 green A8 is offline
Just a quick question. Why did the MOT teater refuse to continue testing when it was apparent that the smoke was merely oil burning off on the exhaust with no danger of a fire? I hope he didn't charge you. My MOT man simply wiped the very hot exhaust system off with a rag and carried on testing, once he was satisfied that there was no danger of fire.
Secondly. Are you 100% sure it's transmission oil that's causing the problem? I had a high miled ABZ 4.2 engine start this lark last year, like you I blamed the tranny seal and had it replaced (about £165 all in if I remember correctly) Only for the car to carry on smoking! On further investigation it was found to be ENGINE oil leaking from the back of the cam covers down the back of the engine block via the bellhousing and from there onto the left hand cat. Once the troublesome gaskets were replaced and the engine was cleaned down the smoking stopped. I think all in the repair cost ran up to £320-330
Hope this helps
