Old 13th September 2013, 03:59 PM
Cupra's Avatar
Cupra Cupra is offline
Default switching live on ignition feed
Just fitted the head unit and it appears that the car has no ignition switching feed (yellow on ISO) can you use the blue 12v + that switches the amp on and off? or is it a case of tracing from the fuse box ???
Old 13th September 2013, 05:53 PM
Some VAGs have the permanent at switched 12v round the other way.. Have you checked the other feed?
Old 13th September 2013, 06:05 PM
Cupra's Avatar
yes, the yellow has no feed to it on the car its self, ive joined the red and yellow and it works, disconnect the yellow from the red and nothing even used a multimeter and getting 0 volts
Old 13th September 2013, 08:27 PM
That's a bit strange... Checked all the fuses? Or if someone has bodged a car kit connection inline.
Old 15th September 2013, 11:04 AM
Cupra's Avatar
it was totally standard, used an autoleads converter and nothing, im think about adding a relay and a feed from something that is ignition switched
Old 15th September 2013, 11:23 AM
There is definitely switched feed, it must have lost connection somewhere, have you checked fuses?
Old 15th September 2013, 11:28 AM
Cupra's Avatar
i will recheck them
Old 15th September 2013, 01:56 PM
Cupra's Avatar
All fuses are ok, Now im stumped
