Old 23rd July 2009, 06:15 AM
Originally Posted by AVPerformance View Post
The standard box draws cool, un-disturbed air from the wheel arch and
I hate to be picky but....
The air for the airbox on the V8s is drawn from the front at the bonnet opening down to the botom of the air-box. It should be from a high pressure area of the cars frontage. As a car moves trough the air it forces it over, under and around it. Good article on the benifits of intake location here:
Pt1
Pt2
Pt3
Pt4
Pt5
I built a manometer and ascertained that there is little presure drop throughout the 8's inlet tract.
Old 23rd July 2009, 09:13 AM
CliveH's Avatar
CliveH CliveH is offline
Default Facelift S8
I was going to have a go at this until I inspected the airbox when changing the MAF and discovered that the secondary air injection and related plumbing may hamper this operation...
any thoughts?
Old 23rd July 2009, 10:00 AM
Short version of post: Drilling Holes?? Making your engine chew on hot air??? Yobs! Bet it sounds nice though
Bill
Long, Waffly, I'm on holiday and bored mindless already, version of post: In addition to Mike I would add that the importance of SMOOTH and fast air flow through the inlet side of things cannot be over stated. lest we forget that the fuel is suspended in said airflow in tiny droplets. Any disruption in that airflow can lead to the fuel dropping out and pooling in parts of the inlet tract. A bad and restrictive thing, very separate from the beneficial "coating" of the inlet tracts on a closed throttle that enables a smooth and predictable transition from open to closed throttle, very important on motorcycles. Much like the exhaust system the inlet side of things is subject to pressure waves and weird harmonics. These are tuned by altering length, diameter and path to produce the desired power characteristics.*# The airboxes role in this is to provide a reservoir of air going in the right direction with no unwanted swirls and eddies at the right temperature. At higher speeds of 50mph or more, on a vehicle with its intake in a high pressure area at the front of the vehicle, the airbox is vital in containing that extra pressure and managing it to the benefit of performance. With respect, drilling holes in an airbox, from a purely engineering point of view, is a bit daft. From an oik's point of view, such as mine , it's worth it for the noise.
Ben your reservoir of knowledge is far greater than mine, I get the bit about cone filters, used them on a spare gsx1100 engine and they were a ******* to jet right at low engine speeds. I don't get this bit "and boxed off so that it only draws air from behind the head lamp. This is a good area to draw from. If drilled carefully then it will give better throttle responce, free-er revving and actually make the engine more efficient as the losses caused by inducting air are reduced....... slightly!" Drilling holes in it stops it drawing from behind the headlight doesn't it.. I'm being thick and I'm in holiday bored mode and I own a drill and I'm daft enough to start hacking away at things for fun and I've had to use the word OOOPS far too many times so please clarify before I hurt my unsuspecting car, again.
Bill
*(For those of a nerdy disposition I would recommend digging up the research papers published by Lotus in the late eighties and early nineties on this subject. Their follow up work on hyper efficient two stroke engines is fascinating too. ).
#On motorcycles they now have to tune the inlet tracts on sports bikes with bungs and flaps because the inlet side of things was making more noise than the exhaust. Does anyone else recall a car at the meet that made more noise from the front than the exhaust?
Old 23rd July 2009, 10:44 AM
any thoughts?
You just have to drill around it mate, mines there also +
Old 24th July 2009, 04:30 AM
wizzard1222
Guest
Posts: n/a
Cool How about a vagcom test...before & after
No; its before the MAF and filter. The only thing that might happen is a small loss of performance due to it sucking hot air from the engine bay. This however may be offset by the extra breathing capability!
How about a vagcom test on performance...? Could do it w/the holes and then duct tape them for another test!
Just a thought!
Old 24th July 2009, 11:53 PM
CliveH's Avatar
Just a thought!
Might be easier to test before drilling the holes and then after? That way you dont need to tape up the holes...just a thought...
Old 25th July 2009, 08:43 AM
quattronutter quattronutter is offline
i already tried this,no increase in maf reading's,a better flowing filter may help,or a larger airbox feed
Old 4th August 2010, 10:55 PM
alefustec
Guest
Posts: n/a
Default just tried it today and.......
I'm loving the sound my S8 now makes......exactly as described by Singh, so thanks for posting this tip
Old 22nd July 2015, 05:03 PM
andycaca andycaca is offline
my wife is out at a hen-do, i'm bored...
time to get out the dremel
2001 S8 D2
Old 22nd July 2015, 05:22 PM
I can't believe you guys never done this to your XR3i's in the 90's
You'll find that you probably loose a bit of performance (very slightly) but induction noise is very nice. Also possible to open the top of the air box and wedge it open making sure that the filter stays in the top part. You can always close it then if you don't like it. Also a second air box might be worth while.
