Old 19th September 2013, 09:36 AM
I saw a post on Pistonheads yesterday of someone using a mini machine polisher in a drill with some car polish/cutting compound to remove the minor imperfections on some interior wood trim, which might work on mine.
Remember this is not wood, that could be disastrous!
IIRC when I fitted my Vavona door switch panels they looked like a painted thin metal sheet folded over the plastic moulding.
I just touched up scratches with lacquer and re-painted the dark door switch holes with matt black paint (not very well ).
Another minor point to note is to be careful of the lugs when removing the lower sections, which you do first. This is to avoid cracks or breaks.
IIRC the rear door has 2 main lugs that catch on the door panel, on the front and rear "upright" edges (plus lugs that intersect with the upper section near the screw fixings). And there's a set of smaller lugs on the top edge that pop open easily.
So to remove those you prise out gently along the bottom and up the sides until it release those 3 sides, then pop out the top lugs and wiggle it out horizontally to disconnect from the upper section.
Note that the bottom edge has no lugs at all, it's just an easy place to get a tool in and work it round to the lugs on the sides.
The front lower sections are similar but a bit trickier. One of the "upright" lugs is larger than the other, so the smaller one needs popping out first. If you buy new ones you'll hopefully see which way round it is first.
Once the lower sections are out and the 2 screws then exposed are removed the upper sections wiggle out fairly easily.
They are retained with big lugs on the cabin side and smaller metal clips on the outer edge. The easiest way to get them out is to lift and release the outer edge first, just by pushing up from below using the handgrip. Once tilted inwards they pretty much lift straight out.
Old 19th September 2013, 09:51 AM
That's just what they are.
Old 19th September 2013, 09:55 AM
Hiya
I'd found some Myrtle trims with platinum lowers and was considering a colour change - as the finish won't be as robust as the factory.
Most of the trims are still available new via TPS - they priced up at £73.79+VAT before any discount - so if you've got one that's beyond saving that's always an option if the rest are good?
Confused
Do you have surplus myrtle/platinum trims?
And exactly what is available for £73.99 - complete upper trims with myrtle over platinum?
Old 19th September 2013, 10:10 AM
Adrian currently has painted (purple) plastic trim for the door switch panels that he is changing to Myrtle, so no spares presumably.
Old 19th September 2013, 10:44 AM
Confused
No, I was offered a set of Mrytle/platinum for £50 but the platinum bits weren't great, plus wouldn't match. After speaking to an interior trim repairer I decided not to bother.
£73.79+vat buys you any one wood trim from TPS
Old 19th September 2013, 12:04 PM
Can you get a discount at TPS? I might bite the bullet and go for all 4 if I can get myrtle on platinum
Old 19th September 2013, 01:39 PM
Be VERY careful in assuming you need platinum. If yours is similar to mine as in WF interior trim code for platinum, you may want Swing finish (which is what I pictured in my new trims and matches the top of the door trim as the cars have a mix of platinum and swing finish)
If you really do need platinum I can supply all the part numbers you need
The Mertyle/Swing options are sold out of drivers door ones
With lower bits as well it's about £400.....
Old 19th September 2013, 02:29 PM
I actually need 'silver grey' but as that's a special colour, I think platinum is nearest. So Myrtle/Platinum would be the nearest as platinum is lighter than swing I think
Old 19th September 2013, 03:16 PM
It is - platinum in the pics I've posted is the colour of the surround for the door pull handle and the memory seat surround
From what I can work out the full range of PR codes for interior wood trims are:
PR code - name of wood finish - name of door switch surround wood finish - lower trim colour options
5MG - burr walnut - nut brown switch trims with either soul/blues/swing/jazz/platinum/aqua/tango/twist
5ME - Vavona amber high gloss - Bernstein with blues/jazz/aqua/tango/twist OR amber wood with platinum
5MW - Dark Myrtle - myrtle with soul/swing/jazz/tango
5MX - light birds eye maple - birds eye maple with platinum/soul/blues/swing/aqua/twist
Looking again at the pics I was sent of the £50 set which appeared to be platinum, I suspect they were actually birds eye maple finish as I can see code EZD written in 1 picture, which corresponds to that option.
Having typed all that hopefully when you look at the attached Etka print outs, which were too confusing for the TPS bloke I spoke to to deal with, it makes it easier to follow!
Old 19th September 2013, 03:18 PM
Just for info these are the pics of the set I was offered for 50 quid - you can see why it's a struggle to figure out what they are!
