Old 25th September 2013, 08:07 PM
This is what i get to see.
Anyone got any tips on how to remove mirror glass to see whats going on in there.
Old 25th September 2013, 08:24 PM
I wouldn't say that was an unusual angle. Mine used to be jerky with the old mirror glass before it fell out due to missing clips caused by muppet fitting which I think may have been the glass catching as it moved through its arc. Doesn't do it with the new mirror glass I fitted.
It's extremely difficult to see if all the clips are in place without removing the glass, but you then run the risk of breaking some off taking it out if the glass is old-ish. Just lean it fully up or down, use a plastic lever (tiling grout spreader worked great for me) to tweak it off the mount, then move it electrically to do the same from the other side.
Old 23rd June 2014, 11:55 AM
Is there a solution to stop the dipping passenger mirror when in reverse? It rubs me up the wrong way also because as I have to reverse between bollards and tight spaces. I can't see anything distant in that mirror except the floor!
Matt
Old 23rd June 2014, 12:07 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Put the mirror switch in to the middle.
[center]
06 3.0TDI Quattro:
Options:
Old 23rd June 2014, 12:10 PM
As simple as that. Thanks
If the switch was pointing to the drivers mirror would that side dip in reverse?
Matt
Old 23rd June 2014, 12:15 PM
ScottD3's Avatar
Sadly no.
[center]
06 3.0TDI Quattro:
Options:
Old 23rd June 2014, 08:47 PM
Way too low on mine too. I can judge the kerb to an millimetre while inadvertantly taking out a lamppost
