Old 27th September 2013, 04:03 AM
skl63 skl63 is offline
Default Faulty MAF, mass air flow sensor?
Guys,
I am pretty confident I have a faulty MAF (car idles well when it is disconnected). Is it possible to source just the sensor, without the housing etc (looks to be held in by 2 tamper proof screws).
Does anyone have a cheap source of this sensor? Car is a 2000 S8
Scott
Old 27th September 2013, 05:29 AM
Check the Bosch part number(assuming it's Bosch) on it and search for it online.
Old 27th September 2013, 07:23 AM
Dave McB Dave McB is offline
The oe number should be 0280218067
The recon bosch number should be 0986280219
Iv got a brand new Bosch unit in the house I bought for mine that i never used that i can sell u if u like. (im a parts advisor for a large motor factors)
U can have it at my cost if u need it - it was 57.19 - if u want it u can have it for 60 quid inc postage.
Old 29th September 2013, 10:07 PM
Thanks Dave,
I will check the part number and get back to you later today,
Scott
Old 1st October 2013, 07:41 AM
Sure pal, no hurry - it can sit there for another while if not needed for now. Im pretty sure it will come in handy at some point to someone
Old 1st October 2013, 07:48 AM
Is that the complete thing including the tube, or the smaller sensor unit that plugs in from the side? And 4-pin or 5-pin plug?
(I might be interested if not sold elsewhere)
Old 1st October 2013, 11:07 AM
Give it a clean, just for fun, nothing to lose. Take some readings before, put in a ziplock filled with Isopropyl alcohol overnight. Leave to dry. Put back in take more readings and plot the two together to see the difference.
I even brushed it gently with a glass fibre brush. I have one of these, but its too big, so I take a few hairs out and make a small bundle which can fit the opening to reach the metal element.
My theory is, if its gunk/oxidation on the metal element surface that's causing low readings, you need to gently scrape it off. Should be possible since thats how electronics contacts/boards are cleaned, IPA and glass fibre brush.
http://www.expotools.com/acatalog/10...ush-70530.html
or maybe look for a better thinner brush. Ideally a small 90-degree toothbrush with glass fibres is needed.
I can chop off some fibres from my brush and send them to you for free if you want to have a go at making yourself a home made mini brush. Perhaps from some 2mm aluminium tubing or similar?
Old 1st October 2013, 11:15 AM
Scott
They are Torx i think and just screw into the plastic, should be able to remove them.
Old 5th October 2013, 04:49 PM
Sir WIll Sir WIll is offline
Gents,
Changing my MAF if cleaning does not help. Is the right part for a 2002 3.7 Quattro 434440240?
Old 6th October 2013, 04:55 PM
Had the MAF out today and cleaned it with carb cleaner.
Now back in the car but not sure what readings I am expecting with VAGCOM?
Idle when warm is 680 and the MAF is reading about 4.5 G/S
Tags
maf
