Old 5th May 2009, 08:01 PM
Default 17125 - Torque Converter Clutch Circuit Performance or Stuck Off
VagCom threw the following fault code after my test run tonight. I've had it before intermittently. Doesn't seem to effect anything......
17125 - Torque Converter Clutch Circuit Performance or Stuck Off.
P0741 - 35-00 - -
Anyone any ideas?
Old 5th May 2009, 08:08 PM
thebluewhale's Avatar
All I could find was this:
http://forums.audiworld.com/showthread.php?p=23292955
Steve
Old 5th May 2009, 08:12 PM
Or this
http://forums.vwvortex.com/zerothread?id=2841889
Old 5th May 2009, 08:19 PM
Oooo errr. Worrying posts especially as I had the TC in my hands a few days ago. The only thing I don't have is any of the symptoms!
The box is as smooth as it's always been.
This Thread suggests another reason with a problem on the MAF. Think I'll try this remedy first.........
Old 5th May 2009, 08:24 PM
Hopefully it's the fluid level.
I've just found this
http://www.w8forum.dk/forum_posts.asp?TID=813
and there is a RossTech Wiki http://wiki.ross-tech.com/index.php/Main_Page
Hope it's not serious
Old 5th May 2009, 08:25 PM
Another one..
http://www.myautomotiverepair.com/?p=783
All seem to be pointing to a torque converter on it's way out. Probably more likely if you're caning it too
Old 6th May 2009, 06:57 AM
A8 Doc A8 Doc is offline
Clean the MAF sensor first. Good dowse with carb cleaner. No harm in that. And just forget about it until/if something does go wrong.
Old 5th October 2013, 04:26 PM
Sir WIll Sir WIll is offline
I just had this code as I have been looking into a lumpy idle today.
Gearbox drives 100% nothing else noticeable, cleared and not come back but I am also suspecting the MAF may a little sick.
How did you get on?
Old 6th October 2013, 05:03 PM
Hmmm is back again.
Though not sure of MAF is OK and I am getting a fault code from one of the Lambdas also.
Now I will look at fixing the MAF/ Lambda but not much really I can do on the box.
Change the MAF, clear the codes and just drive the thing? If it goes bang then hey time for a D3?
Old 7th October 2013, 08:33 PM
Interesting...
Drove the car for ages tonight to look into the problem a little more.
Drive at a constant 45mph, all is smooth no rev jumps.
Gear changes up and down all good, quick and smooth
Car accelerates as expected, kick down etc all good
Goes into Drive and Reverse quickly and no clunks
Does not stall or grumble in anyway
Looking at the codes again I now have P0155 (O2 Sensor Pre Cat), P0171 (System too Lean Bank 1) and P0174 System too Lean Bank 2).
All combined is never good and after cleaning the MAF its not made any change to the car.
It could be a hope the 17125 is linked the MAF/ 02 problem but its worth spending the few quid for new parts to check it out.
