Old 14th October 2013, 11:04 AM
ulfilias ulfilias is offline
Hi There,
Replaced the G40 sensor and that error has gone away.
It's not the fuel system as the car has LPG. It runs slightly worse on LPG, which is actually common when you get a fault as it is less forgiving than petrol.
I expected it to be the coil pack on cylinder no.1 but i've just swapped 1 & 2 and there is no difference, if anything slightly worse, though takes 30 second to generate the missfires 1, 3, 4 (2 didn't even come up).
However the 1st code in the list is now
17549 - Load Calculation Cross Check: Implausible Value
P1141 - 35-00 - -
Any ideas ???
