Old 18th October 2013, 07:33 PM
Thanks very much, that's EXACTLY what I needed to know.
I'll get my trusty multimeter out to check as well. My labelling is rather different though, which is why I was
To be specific, the 8-connector block at the top, which is of most interest, has:
Top line: Earth, "Sun", S.Kont, TEL MUTE
Bottom: UB+, SAFE, K.BUS, GALA
The little aerial (what is that?) on the picture above is SAFE on my RNS-D which I believe is a permanent +12v to stop you re-entering the security code.
And what is K.BUS - anyone know?
By the way, the individual wires going into the CD unit are fairly accessible with the cable cover/clamp removed.
Colour codes on the CD Changer fly-lead seem different, but the plug is also fairly easy to open so identifying them by position should be easy. The plug is numbered and correctly "mirrors" that above.
EDIT: Found some info online which suggests your picture is of a Symphony radio label which is "slightly" different and doesn't require a separate "SAFE" wire.
RNS-D is like the attached picture:
