D2 - Sat Nav, ICE, Audio & TV All in car entertainment discussions |
OK, I've got the coding table, here's a sort of interpretation:
Radio soft code is 5 digits, all are binary values from 0 to 7. The three options within each field are valued at 1, 2 or 4 (for on) and are added to give the value. Standard binary stuff. First digit = 0 Second digit = 0 for A8 or Bose (Sound curve, uses other values for other models without Bose, e.g. A6-C5 is 2) 3rd digit = FaderOff(1), BoseDisplay(2), ActiveAmpPhoneDeactivate(4) 4th digit = Navigation(1), Telephone(2), VCS(4) 5th digit = DiversityBox(1), CDchanger(2), MFSW(4) Not sure that makes sense of my 00117 and 00207 codes though. ![]()
Be aware that USA coding seems to be nowhere near the same as Europe. I found coding values quoted for our A6 that were completely off the wall compared to what it should be!
I read the code off the A6 stereo to know what to change it for, but when I got in to the soft code entering page it came up with a guided list of each number to enter which tallied with what I had from the old one
HP, what ELSA suggests?
I'd rather drive on left |
Good point - forgot it was in there! Attached....
Now that makes much more sense.
![]() The coding I have is in your document as MY02 onwards. The "up to MY 01" seems to make total sense on all the kit I have, even though my car is a D2 made in 2002 (registered 2003!). 00117 is pretty standard Bose. 00207 is standard non-Bose with powered rear speakers. 00507 would be for unpowered rear speakers. Given my rear speakers are so useless I wonder if they are powered or not - will have a look tomorrow if it's not raining. ![]() I have the fader set heavily to the rear to compensate. ![]() (I had the covers off when fitting the ski hatch but didn't inspect the wiring ![]() Edit: Thinking about it, the rear speakers were working when coded for Bose, so that suggests that they are indeed powered. Odd they're so quiet though. ![]()
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 4th November 2013 at 08:37 PM. |
![]() What sort of voltages are used in each case - anyone know?
I think if you code RNS-D 'non-BOSE' you won't hear anything since in BOSE config RNS-D send L and R signal to BOSE amp via line-out pins and doesn't use normal directly connected speaker pins. If your car had BOSE from day one your speaker pins are not connected. The sound goes from RNS-D pre-amp via line-out pins to BOSE amp in your boot.
Well yes, but non-Bose mostly still use amplifiers for the rear speakers. Which is why it's an option in the coding tables for RNS-D.
The amplified speakers have extra wires as the amps are in the housing under the parcel shelf. And according to one source I read they then feed the rear door speakers. The FACT that I had sound from my rear speakers (door & shelf, but not front door) with Bose coded in the RNS supports that. Which connections are used from the RNS I don't know, but it would make sense for the fronts to use the powered connections and rears to use the lineout ones in that "mixed" configuration. Quote:
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 4th November 2013 at 09:55 PM. |
Was your car manufactured as BOSE car?
