Old 19th November 2013, 07:11 PM
Default D3 Pre and post facelift differences
Looks like I am in the market for a D3 to replace the 3.7 D2 QS.
Budget is 6K max, and in that range I see that early facelift D3's are now creeping in under that figure.
Do all the diesels have DPFs?
Apart from the obvious styling changes at the front, what are the other main differences?
Old 19th November 2013, 07:54 PM
No, initially it was just the A8L.
If it has one, it will say EU4+DPF on the emmsissions sticker under the bonnet.
Getting one hollowed out and reflashed ECU is not that expensive.
Old 19th November 2013, 08:45 PM
jza8's Avatar
jza8 jza8 is offline
Am I the only one who bought pre-facelift because I prefer the look?
Old 19th November 2013, 09:53 PM
Air suspension
More gears in the box
Fingerprint unrecognition
Standard MF steering wheel
Much more power
More economical
Better lights, brakes
And.... The one manufacturers always state blah% stiffer body. This one is clearly impossible otherwise by now all cars would be as stiff as a block of granite (or a porn star (male))
Oooo almost forgot this one. The D2 is lighter and it drives better (less twitchy), at least in my limited experience
Old 20th November 2013, 06:54 PM
jza8's Avatar
I ment about D3 pre and post-facelift.
Old 20th November 2013, 07:13 PM
Your welcome
Old 21st November 2013, 06:46 AM
As above, but wasn't DPF a legal requirement on all cars manufactured from 2005 ???
I would push for a facelift model no matter what, honestly.
Old 21st November 2013, 09:18 AM
Greg66 Greg66 is offline
Rectangular front fogs, redesigned rear light cluster, improved sound deadening in the cabin. Side assist and Lane assist (amongst other things) only became available as options post FL, I think. HDD sat nav came in after the FL, in 2009.
There's an unresolved question as to whether the Torson diff changed from the T2 (50/50) to the T3 (60/40) at FL time, or whether it was always the T3. Wiki says it changed, but I think it may well be wrong on that.
Old 21st November 2013, 10:00 AM
Norretal's Avatar
Norretal Norretal is offline
Your welcome
I couldn't help......at that response
Audi TT - 2015 - Ultra
Old 21st November 2013, 11:28 AM
I suppose this was really FL2 as there was original D3 with split bumpers, then FL1 with the one piece grille and round fog lamps, then FL2 as described above
