Nope, a load of the controllers time out. Some work and some don't, however if I scan again different ones work which is why I tried several times the battery one.
Sure thing - I have 2xM10 and an M8 rivnut which I'll send down to you.
Are you sure it's the cable and not the module? Some say that jump starting the car can fry the module (not witnessed that myself despite a few jump starts due to failed alternator)
2004 A8 3.0 TDI Sport Brilliant Black - now gone |
Everything in the car works as expected, and I remember having issues with CAN on another car. The modules when I can connect to them, do have faults relating to low voltage which once cleared don't return.
Just been out to the car and managed to connect to the battery module, selected coding-07 and changed the battery serial number but keep getting coding rejected error.
The module is already coded for the correct battery make and type, so it was not recoded when the previous battery was installed. If I try a VCDS auto scan, I get this far and then lots of failures saying controller not responding. 0-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: OK 0000 1D-Driver Ident. -- Status: OK 0000 1E-Media Player 2 -- Status: Malfunction 0010 25-Immobilizer -- Status: Malfunction 0010 28-HVAC, Rear -- Status: Malfunction 0010 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: Malfunction 0010 37-Navigation -- Status: Malfunction 0010 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 57-TV Tuner -- Status: Malfunction 0010 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: Malfunction 0010 VCDS then reports a problem with the cable, and the scan aborts. They all used to say malfunction, I have managed to connect to some and clear the fault codes which then do not return.
Manny 2004 A4 1.8T Sport Cabriolet, 89K Miles Past 2004 D3 A8 3.7 Quattro, Xenon, Bose, Blinds, Solar Sunroof, TV, ACC, phone and almost every option. 168K miles rising slowly with retrofit AMI and DVB-T in place of Analogue 2003 Volvo S60 D5 SE Manual, 197K miles. 2001 D2 A8 3.7 QS, Bi-Xenon, Bose, Blinds, Electric Everything, retrofitted RNS-D, 191K Miles Last edited by mannyo; 11th December 2013 at 12:46 PM. |
did you manager to see the software version while it was connected
Did not manage to get software version.
I am currently running VCDS on a MacBook pro inside a VMware Fusion VM with USB being passed through from OSX. I'll see if I can borrow a windows laptop from work, maybe the VM is not helping things.
I have borrowed a laptop from work and installed VCDS, and managed to do a full scan successfully. I have erased all the fault codes, but some returned. This is the scan from the battery module.
Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 A HW: 4E0 915 181 Component: ENERGIEMANAGER H02 0230 Revision: 00000000 Serial number: 00000003801107 Shop #: WSC 00217 217 52026 VCID: 1E37DA4BB027 Part No: 000 915 105 AK Component: von VA0 1308220419 Coding: 303030393135313035414B56413031333038323230343139 Shop #: WSC 00000 128 00289 No fault code found.
