Old 14th January 2014, 04:49 PM
i wouldnt mind a copy of that iso if you can stick somewhere i could get to
Old 14th January 2014, 05:21 PM
I've sent you a PM.
Old 14th January 2014, 05:50 PM
Was thinking it would be good to add to the archive
Old 14th January 2014, 06:15 PM
will stick it in the usual place on the resource
Old 14th January 2014, 06:32 PM
Could not resist, so just spent another 50 mins sitting in the car with the engine running.
MMI now upgraded to 5150, took two passes of the CD to get it fully complete. Everything is still working. Phone, Bose, Radio, CD, TV, Nav. I do wonder if the phone I have which appears as TEL_EU during the update is affected by all the problems.
Still debating if I should use CD 2 and CD 3. Not sure how good Poole Audi are at removing component protection, should the Bose decide to activate it.
Old 14th January 2014, 09:29 PM
I'd definitely do disk 2 and 3, though I think 2 is just the BT kit.
Mine went into CP, but another run with the disk sorted it out.
Old 14th January 2014, 10:24 PM
I've now got the password for the copy I have and it's hosted on rapidshare if that helps
Old 15th January 2014, 12:45 PM
I bit the bullet and ran the last CD, since CD2 is of no use to me. All seems to be working fine on 5570.
Old 15th January 2014, 10:54 PM
B17NKA B17NKA is offline
Hello
I have a 57 plate A8 3.0 Tdi,how will I find what version mine is and what benefits will I get by upgrading it ?
Cheers Andy
Old 16th January 2014, 06:57 AM
The only list of changes, I have pasted below. Its worth noting that the new 2014 NAV disk when released will require 5750 to work.
For version, depends on the version you already have. its either on the car screen, bottom right version button. or its in the systems menu under version.
New features:
Audi Parking System Plus can be retrofitted (Audible and graphic display of the screen)
DSP allows higher volume
Navi Announcements can be turned off during call
Volume of the background music during navigation announcements can be set
Height information can be displayed in the Navigationmap
Route can be followed on the chart via the MMI control
Crosshairs on input card is easier
Additional display arrows for the direction in which the POI will be looking for points of interest
Better labeling of highway exits at low zoom levels
Voice control and navigation of the top targets are immediately available
Bluetooth: access to more phonebook memory
Configurable Bluetooth PIN
If you select a POI in navigation, then you can dial the number directly.
VCS (voice control system) is available in conjunction with Hands free kit.
Sound Setup: Setting DSP Driver / Symmetric is not saved. Always remains on symmetric
On vehicles with DSP may cause a total failure of all the speakers. Ignition off for a long time to correct the problem.
DSP forgets DRIVER / SYMMETRIC setting is fixed.
Bird-view navigation menu is selectable 3D map display.
AMI (Audi Music Interface) is now upgradeable to connect IPOD, USB sticks, hard drives, etc.
MP3-CD changer support few changes are known.
Bose surround will not forget the surround setting
Trouble-free integration of the new iPod generations.
