Old 16th January 2014, 11:12 AM
Default Diagnosing RPM related high pitch whine/noise
Hello all,
My D2 FL suddenly developed a high pitch whine, which can be clearly heard when I sit in the car while the car is parked.
Noise is clearly RPM related, but it is difficult to say where the noise comes from. Not even sure at this stage if it is from the front or from rear of the car. I appreciate there is nothing from rear that can generate RPM related noise, but simply judging by ears it is impossible to say where it comes from...
It is high pitch whine that kind of disappears with higher RPM perhaps because frequency goes so high that it becomes undetectable by human ear. Engine is revving a bit after 2000-3000 rpm, so it hides the noise too.
I tried to switch aircon on and off and play with steering wheel. Noise pattern does't change when I do that. It seem to be RPM related only.
* Is this bearing noise? No bearings in my car were changed yet.
* Can the RPM-related noise/whine be generated by smth other than bearing?
* In your experience which bearings fail first on D2? Any usual suspects?
* What are the best methods to isolate and diagnose problem?
* Any great tools I can buy that will help me to listen and isolate sources of noises/whines?
Any advice will be appreciated.
Old 16th January 2014, 02:56 PM
Try this: http://www.ebay.co.uk/itm/MECHANICS-...item19e765e664
Old 16th January 2014, 03:29 PM
Thanks Jim.
Purchased the Stethescope: http://www.ebay.co.uk/itm/321265618327
Old 16th January 2014, 11:00 PM
High pitched whines i my experiences have turned out to be bearings on things like fan belt jockey wheel /Idler Pulleys.
Once you your ear thing comes it will be easy to pinpoint it if it is a bearing race complaining.
You could try the old screwdriver handle held to your ear with the tip resting against the area you want to listen too.
Old 16th January 2014, 11:15 PM
Thanks Delboy
Old 17th January 2014, 07:17 AM
Sergey, you could also try just removing auxiliary belt from the crank pulley, run engine for a few minutes on battery only, if no noise it was something on the auxiliary belt.
I did this method on my previous S8. I had 2 noises, one was a timing belt roller, the more fain noise was the water pump.
