Old 17th January 2014, 08:22 PM
B17NKA B17NKA is offline
Hellish will have a look to see what my version is
Regards Andy
Old 18th January 2014, 12:09 PM
Just did a VCDS scan of my car, since I have fixed the alarm now and wanted to clear the fault code.
However the MMI upgrade has left my DSP in component protection, sound appears to be normal and coming from all channels however. Both faults come back straight away.
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300IT037524996
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 3A7F36DB0CCF
Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 33
Mileage: 208014 km
Time Indication: 0
Date: 2014.01.18
Time: 12:48:54
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H00 0460
Coding: 0000017
VCID: 2A5F069BFC6F
1 Fault Found:
02084 - Component Protection
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 30
Mileage: 207994 km
Time Indication: 0
Date: 2014.01.14
Time: 19:14:48
The car is going into my local indy next Tuesday, I wonder how friendly they are with the Audi dealer.
Old 18th January 2014, 12:57 PM
I've fixed the control head fault code, adaption channel 12 had forgotten the type of phone installed. Changed it to "1" and the fault has cleared.
All I have left is the component protection on the DSP.
Old 18th January 2014, 01:24 PM
not too bad then, year ago cost me 25 gbp at the dealers
Old 18th January 2014, 03:27 PM
Check the settings on the DSP too, it's showing a coding error..
Old 18th January 2014, 03:30 PM
I think the reason its apparently still working normally is that I only have the 02084 - Component Protection fault code. Looking at other forums, those with operational issues seem to also have, 02095 - Component Protection Active. I don't have the latter code at all.
Since it seems to be working (have yet to do a long drive), its a low priority issue to me. I have emailed my indy to see if they can take it to Audi when they have the car next week, the dealer is a couple of miles from them. If they cannot then it will wait till I can get some time of work.
Psyche. I dont know how to check the settings for coding. I have the scan from before and after, I'll post below.
After:
Coding: 0000017
VCID: 2A5F069BFC6F
Before:
Part No SW: 4E0 910 223 E HW: 4E0 035 223 A
Component: DSP-Amp.-High H00 0210
Coding: 0000017
VCID: 1F49E74FB72D
Apart from the software version, they look the same.
Old 18th January 2014, 04:33 PM
Searching the internet, the number of people that have the same fault code on 47: sound system as my last one. None seem to mention issues with sound quality.
Old 18th January 2014, 09:19 PM
Go into the DSP module in VCDS, click on coding, and just check it against the options list. Worst case, just re-save what it has and see what it thinks.
Old 19th January 2014, 10:09 AM
re saving the existing code makes no difference, the error remains. I even checked adaption channel 96, which is coded correctly. Ran the very loud output tests and they are fine as well.
I have enabled the hidden system menu and turned the battery meter back on now though.
Old 19th January 2014, 03:35 PM
Somerandomguy's Avatar
Thats exactly what mine was like after the MMI upgrade from a slightly younger version, VCDS showed a component protection error, but the sound was perfectly fine. I got it removed at the dealers for £70.
I need to go back to get the replacement instrument cluster sorted, so if anyone knows any cheaper dealers in kent......?
