#31
Hellish will have a look to see what my version is
Regards Andy |
#32
Just did a VCDS scan of my car, since I have fixed the alarm now and wanted to clear the fault code.
However the MMI upgrade has left my DSP in component protection, sound appears to be normal and coming from all channels however. Both faults come back straight away. Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300IT037524996 Coding: 0000002 Shop #: WSC 02313 785 00200 VCID: 3A7F36DB0CCF Part No: 4E0 910 609 A Component: Bedienteil MMI H42 0020 1 Fault Found: 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 33 Mileage: 208014 km Time Indication: 0 Date: 2014.01.18 Time: 12:48:54 Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 P HW: 4E0 035 223 A Component: DSP-Amp.-High H00 0460 Coding: 0000017 Shop #: WSC 02313 785 00200 VCID: 2A5F069BFC6F 1 Fault Found: 02084 - Component Protection 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 6 Fault Frequency: 1 Reset counter: 30 Mileage: 207994 km Time Indication: 0 Date: 2014.01.14 Time: 19:14:48 The car is going into my local indy next Tuesday, I wonder how friendly they are with the Audi dealer.
#33
I've fixed the control head fault code, adaption channel 12 had forgotten the type of phone installed. Changed it to "1" and the fault has cleared.
All I have left is the component protection on the DSP.
#34
not too bad then, year ago cost me 25 gbp at the dealers
#35
Check the settings on the DSP too, it's showing a coding error..
#36
I think the reason its apparently still working normally is that I only have the 02084 - Component Protection fault code. Looking at other forums, those with operational issues seem to also have, 02095 - Component Protection Active. I don't have the latter code at all.
Since it seems to be working (have yet to do a long drive), its a low priority issue to me. I have emailed my indy to see if they can take it to Audi when they have the car next week, the dealer is a couple of miles from them. If they cannot then it will wait till I can get some time of work. Psyche. I dont know how to check the settings for coding. I have the scan from before and after, I'll post below. After: Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 P HW: 4E0 035 223 A Component: DSP-Amp.-High H00 0460 Coding: 0000017 Shop #: WSC 02313 785 00200 VCID: 2A5F069BFC6F Before: Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 E HW: 4E0 035 223 A Component: DSP-Amp.-High H00 0210 Coding: 0000017 Shop #: WSC 02313 785 00200 VCID: 1F49E74FB72D Apart from the software version, they look the same.
Manny 2004 A4 1.8T Sport Cabriolet, 89K Miles Past 2004 D3 A8 3.7 Quattro, Xenon, Bose, Blinds, Solar Sunroof, TV, ACC, phone and almost every option. 168K miles rising slowly with retrofit AMI and DVB-T in place of Analogue 2003 Volvo S60 D5 SE Manual, 197K miles. 2001 D2 A8 3.7 QS, Bi-Xenon, Bose, Blinds, Electric Everything, retrofitted RNS-D, 191K Miles Last edited by mannyo; 18th January 2014 at 03:32 PM. |
#37
Searching the internet, the number of people that have the same fault code on 47: sound system as my last one. None seem to mention issues with sound quality.
#38
Go into the DSP module in VCDS, click on coding, and just check it against the options list. Worst case, just re-save what it has and see what it thinks.
#39
re saving the existing code makes no difference, the error remains. I even checked adaption channel 96, which is coded correctly. Ran the very loud output tests and they are fine as well.
I have enabled the hidden system menu and turned the battery meter back on now though.
Manny 2004 A4 1.8T Sport Cabriolet, 89K Miles Past 2004 D3 A8 3.7 Quattro, Xenon, Bose, Blinds, Solar Sunroof, TV, ACC, phone and almost every option. 168K miles rising slowly with retrofit AMI and DVB-T in place of Analogue 2003 Volvo S60 D5 SE Manual, 197K miles. 2001 D2 A8 3.7 QS, Bi-Xenon, Bose, Blinds, Electric Everything, retrofitted RNS-D, 191K Miles Last edited by mannyo; 19th January 2014 at 10:51 AM. |
#40
Thats exactly what mine was like after the MMI upgrade from a slightly younger version, VCDS showed a component protection error, but the sound was perfectly fine. I got it removed at the dealers for £70.
I need to go back to get the replacement instrument cluster sorted, so if anyone knows any cheaper dealers in kent......?
2004 A8 3.0 TDI Sport Brilliant Black - now gone |
