Old 21st January 2014, 03:25 PM
Stevie Stevie is offline
Default Brake Pads ...
Ok, Brake Pad light came on today.
Rang Audi for replacement cost --> £300 fitted.
Kwik Fit --> No real price suggesting it should be around the £100 mark, but making noises about wear sensors may need to be replaced.
Any views?
Old 21st January 2014, 03:37 PM
Avoid Kwik Fit at all costs, had bad experiences with them and brakes in the past.
Old 21st January 2014, 03:58 PM
£300.. They gold plated???
Wear sensors should be integrated in the '8s pads.
Old 21st January 2014, 04:09 PM
Is that just the fronts or all round?
The last lot of OEM front (D2 S8) pads I had replaced were far from cheap and way over £100 for the parts.
That was at Fontain, not sure on the labour as several other jobs were done at the same time.
Old 21st January 2014, 04:21 PM
£300 just the front pads. ... Front Disks and Pads = £800
Old 21st January 2014, 04:23 PM
D4 front pads are £220-500 from dealer depending on brakes fitted. Some of them come with separate sensor wires( not sensors, just separate connecting wires). Yours must be one of the 2 cheaper options £223 or £231 plus the labour.
Aftermarket pads are under £80 at eurocarparts.
Old 21st January 2014, 05:01 PM
Try these folk for a price
http://www.murraysdirect.co.uk/
Usually only stock good quality German brands - you'll need to ring as their web site is useless except for contact details!
Old 21st January 2014, 06:42 PM
They aren't.
Old 21st January 2014, 07:11 PM
I'm pretty sure that Audi / VAG don't make brake pads
Old 21st January 2014, 07:50 PM
Forgot yours was a D4.. so they're possibly be different... My D2 and D3 are integrated.
And yes, VAG don't make pads, but some of the aftermarket (Pagid being an example), aren't as good as OEM quality.
