Old 4th June 2009, 08:57 PM
CliveH's Avatar
CliveH CliveH is offline
Default Has anyone fitted RNS-E?
Sorry if this has already been asked but couldnt find it.
Has anyone done it? Is it possible or are there fitment or interface issues?
Old 4th June 2009, 11:29 PM
Botang Botang is offline
Yep its been done, A8 Tony has one in his car and their are a few more about the country too, I think from memory they use the A6 RNS-E.
Old 5th June 2009, 07:58 PM
gninnam gninnam is offline
Yep - A6 unit.
Just have to trim the outside of the unit to fit the smaller appeture of the A8. (mine is FL model, not sure if the PF is a different fit?).
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 6th June 2009, 12:53 PM
CliveH's Avatar
Thanks for the replies guys
Other than trimming the A6 unit for fitment, are there any interface issues or is it just straight plug & play?
Old 6th June 2009, 02:35 PM
A8_Tony's Avatar
A8_Tony A8_Tony is offline
If only.
There's quite a significant amount of work to do to make the unit electronically fit the '8's. Worst of which is the hooking into the back of the dash into the CANBUS hi and low wires.
However, it's well worth it. The sound is much better than the RNS-D unit, you get the obvious 3D satnave, and you get 2 SD card slots behind the display that can be used for music.
The swap is well documented on the web, so don't be scared off
A8OC Founder
The A8 Owners Club here
Old 6th June 2009, 03:01 PM
It used to be scary, but I think its been dont enough times now....
If you already have a facelift car with a double din sat nav, its pretty easy.
http://www.kufatec.de/shop/index.php...aad34686a4d712 -
Kufatec will provide you with a cable loom for about £40 that will adapt the existing audio unit to the RNS-E multi block connectors which are significantly different - the £40 is worth it. They also do a convertor for the RF aerial and GPS aerial connections which makes life easy.
Physically, neither the A6 nor the A4 unit will fit perfecty. The A6 will be slightyl too wide, and the A4 one is slightly too narrow (mm or so, barely noticable) and too tall, but can be shaved down.
Expect to pay 50% extra for an A6 unit over the A4 ones though, hence the temptation to go with the A4 unit and 'make it fit'...
Old 6th June 2009, 06:35 PM
CliveH's Avatar
Thanks guys, very helpful
Old 17th August 2009, 08:48 AM
Default Rns-e
Originally Posted by A8_Tony View Post
If only.
Tony - can you point us to the fitting instructions on the web? And have you got a piccy of yours? I'm tempted..
Ian - how much for an A6 RNS-E?
Old 17th August 2009, 08:59 AM
quattronutter quattronutter is offline
Default try this
http://forums.audiworld.com/showthread.php?t=1758989
Old 17th August 2009, 09:00 AM
Shark_90 is going to do mine, might be worth dropping him a PM .
