Old 17th August 2009, 02:59 PM
Oh, bloody hell! That is just too scary! My '8 is an every day car, so that would keep it out of use far too long. I'll get in touch with Shark_90. Wher's he based and did you have to supply the head unit?
Old 11th October 2009, 12:12 PM
rutgerf's Avatar
rutgerf rutgerf is offline
Just bought meself a Rns-e also to replace the rns-d
Now i am a bit confused about what adapter cable i need to have
Can someone tell me witch adaper cables i need to order from kufatec??
The direct link Ian post earlier doesnt seem to work.
Its for a s8 2000 with bose sound
Thanks
You only need 2 tools: WD40 and Duct Tape. if it doesn't moves use WD40... if it moves but it shouldn't use Duck tape
Old 30th October 2009, 06:37 PM
sutherland sutherland is offline
Originally Posted by Ian@A8Parts View Post
Physically, neither the A6 nor the A4 unit will fit perfecty. The A6 will be slightyl too wide, and the A4 one is slightly too narrow (mm or so, barely noticable) and too tall, but can be shaved down.
Anyone know where I can see a photo of an A4 unit in an A8? I'd like to see how noticeable or not the mm gap is.
Old 9th November 2009, 09:19 AM
rutgerf's Avatar
Here ya go
Old 9th November 2009, 09:53 PM
Thanks
Try this:
http://www.kufatec.de/shop/product_i...udi-A6-4B.html
And if it doesnt work, just follow the A6-4B chassis and go through unil you find and RNS-E retrofit cable. the A6 (pre 2005) and A8 are identical as far as wiring is concerned in this case, so just fill in the questions and say you have an RNS-D.
Product number 33405.
Also note you will need aerial adapters for converting the RNS-D radio and naviation aerials to the RNS-E connectors.
Hope that helps.
I'm seriously contemplating putting an RNS-E in my D2 at the moment, so I might (famous last words) do an end to end write up....
