Old 5th February 2014, 05:53 PM
Originally Posted by mannyo View Post
its right down by your feet, if you feel around the lower dash trim you should find it.
Yeah, sorry, closer to your feet than to a steering wheel
just on the edge where the trim under steering wheel is.
Recently I was thinking about moving it somewhere less annoying as its only a harness clipped to the trim.
It can be so awkward when you have to plug the cable in from outside with closed door and window down (often during calibration or lowering suspension)
There is a little compartment on the bottom right from the steering wheel which you can open and close. I was thinking to fit it in there.
It can be so annoying when you have to plug in and out many times.
