Old 10th March 2014, 06:40 PM
audifin audifin is offline
Default Would these Q3 wheels fit D3 A8?
http://www.ebay.co.uk/itm/GENUINE-AU...item27e035df69
Not that I'm willing to pay that much That tyre size was available as standard in 2006 brochure.
Old 10th March 2014, 09:46 PM
7.0J ET43
Doesn't sound right, pretty sure you should be looking at 8 or 8.5J for a standard A8 fitting.
Old 10th March 2014, 10:20 PM
Yep, standard ET starts from 45 if I remember right.
As for wheels, don't know whats the J and ET on 17s, but standard 18s are ET45, 8.5J and 255/45 tyre
Old 10th March 2014, 10:30 PM
Can't see why they would not fit. PCD is the same 112mm, centre bore might be bigger at 66.1mm instead of 57.1mm but you can use spigot rings. And it will be harder to kerb them as they are narrower tyre will hit the kerb first.
Old 11th March 2014, 07:36 AM
Thanks for the replies guys.
235/50/18 was a standard tyre size too, but it was indeed on 8J rim, not 7J.
Old 11th March 2014, 07:55 AM
it depends on what size your existing wheels are how much the difference would be but as an example vs a standard 18" QS wheel -
As you can see the only difference would be the thin-ness of the wheel meaning that to get the wheel to line up with where you want it on the face you may have to fit spacers. . .
