Old 1st April 2014, 10:16 PM
Kalchev Kalchev is offline
I'll take another pic on tarmac. I may have shot this one with a slight angle
Goran thanks for the hint about the option codes in the service manual - I checked months ago in the spare tire well, but it had been changed with the bigger version in order to get the lpg tank in there, so the options were from another audi.
After checking the decoder, this is what came out regarding the suspension:
1BM = Standard suspension/shock absorption
0YT = Weight range 18 installation control only, no requirement forecast
0JK = Weight category front axle weight range 10
From your list it seems my rear springs should have 2 green markers. Any chance you have the same list for the front so I can check those too?
Old 1st April 2014, 11:11 PM
Front looks high to me, and the rear normal.
Old 2nd April 2014, 03:53 PM
Of course, here are the front spring options for a 1999 model.
34 4D0411105CT coil spring / 1 paint mark / 2 paint marks violet orange / 6 cylinder: PR-1BA/0JD; PR-1BG/0JD; PR-1BM/0JD; PR-1BN/0JD
(34) 4D0411105CT coil spring / 1 paint mark / 2 paint marks violet orange / 8 cylinder: PR-1BA/0JE; PR-1BG/0JE; PR-1BM/0JE; PR-1BN/0JN
(34) 4D0411105CT coil spring / 1 paint mark / 2 paint marks violet orange / diesel eng., 6 cylinder: PR-1BA/0JE; PR-1BG/0JE; PR-1BM/0JE; PR-1BN70JE
(34) 4D0411105DA coil spring / 1 paint mark / 3 paint marks violet orange / 6 cylinder: PR-1BA/0JE; PR-1BG/0JE; PR-1BM/0JE; PR-1BN/0JE; PR-1BT/0JE;
(34) 4D0411105DA coil spring / 1 paint mark / 3 paint marks front violet orange / 8 cylinder: PR-1BA/0JF; PR-1BG/0JF; PR-1BM/0JF; PR-1BN/0JF; PR-1BT/0JE;
(34) 4D0411105DA coil spring / 1 paint mark / 3 paint marks violet orange / diesel eng., 6 cylinder: PR-1BA/0JF; PR-1BG70JF; PR-1BM/0JF; PR-1BN/0JF; PR-1BT/0JE
(34) 4D0411105DB coil spring / 1 paint mark / 2 paint marks violet grey / 6 cylinder: PR-1BA/0JF; PR-1BG/0JF; PR-1BM/0JF; PR-1BN/0JF; PR-1BT/0JE
(34) 4D0411105DB coil spring / 1 paint mark / 2 paint marks violet grey / 8 cylinder: PR-1BA/0JG; PR-1BG/0JG; PR-1BM/0JG; PR-1BN/0JG; PR-1BT/0JF
(34) 4D0411105DB coil spring / 1 paint mark / 1 paint mark RAUN green / diesel eng., 6 cylinder: PR-1BA/0JG; PR-1BG/0JG; PR-1BM/0JG; PR-1BN/0JG; PR-1BT/0JF
(34) 4D0411105DC coil spring / 1 paint mark / 3 paint marks violet grey / 6 cylinder: PR-1BA/0JG; PR-1BG/0JG; PR-1BM/0JG; PR-1BN/0JG; PR-1BT/0JF
(34) 4D0411105DC coil spring / 1 paint mark / 3 paint marks violet grey / 8 cylinder: PR-1BA/0JH; PR-1BG/0JH; PR-1BM/0JH; PR-1BN/0JH; PR-1BT/0JG
(34) 4D0411105DC coil spring / 1 paint mark / 3 paint marks violet grey / diesel eng., 6 cylinder: PR-1BA/0JH; PR-1BG/0JH; PR-1BM/0JH; PR-1BT/0JG
(34) 4D0411105DD coil spring / 1 paint mark / 2 paint marks violet yellow / 6 cylinder: PR-1BA/0JH; PR-1BG/0JH; PR-1BM/0JH; PR-1BN/0JH; PR-1BT/0JJ
(34) 4D0411105DD coil spring / 1 paint mark / 2 paint marks violet yellow / 8 cylinder: PR-1BA/0JJ; PR-1BE/0JJ; PR-1BN/0JJ; PR-1BM/0JJ; PR-1BT/0JH
(34) 4D0411105DD coil spring / 1 paint mark / 2 paint marks violet yellow / diesel eng., 6 cylinder: PR-1BA/0JJ; PR-1BG/0JJ; PR-1BM/0JJ; PR-1BN/0JJ; PR-1BT/0JH
(34) 4D0411105DE coil spring / 1 paint mark / 3 paint marks violet yellow / 6 cylinder: PR-1BA/0JJ; PR-1BE/0JJ; PR-1BM/0JJ; PR-1BN/0JJ; PR-1BT/0JH
(34) 4D0411105DE coil spring / 1 paint mark / 3 paint marks violet yellow / 8 cylinder: PR-1BA/0JK; PR-1BG/0JK; PR-1BE/0JK; PR-1BM/0JK; PR-1BN/0JK; PR-1BT/0JJ
(34) 4D0411105DE coil spring / 1 paint mark / 3 paint marks violet yellow / diesel eng., 6 cylinder: PR-1BA/0JK; PR-1BG/0JK; PR-1BM/0JK; PR-1BN/0JK; PR-1BT/0JJ
(34) 4D0411105DF coil spring / 1 paint mark / 2 paint marks violet green / 6 cylinder: PR-1BA/0JK; PR-1BE/0JK; PR-1BM/0JK; PR/1BN/0JK; PR-1BT/0JJ
(34) 4D0411105DF coil spring / 1 paint mark / 2 paint marks violet green / 8 cylinder: PR-1BA/0JL; PR-1BE/0JL; PR-1BM/0JL; PR-1BN/0JL; PR-1BT70JK
(34) 4D0411105DF coil spring / 1 paint mark / 2 paint marks violet green / diesel eng., 6 cylinder: PR-1BA/0JJ; PR-1BG/0JJ; PR-1BN/0JJ; PR-1BM/0JJ; PR-1BT/0JK
(34) 4D0411105DG coil spring / 1 paint mark / 3 paint marks violet green / 6 cylinder: PR-1BA/0JL; PR-1BE/0JL; PR-1BM/0JL; PR-1BN/0JL; PR-1BT/0JK
(34) 4D0411105DG coil spring / 1 paint mark / 3 paint marks violet green / 8 cylinder: PR-1BA/0JM; PR-1BG/0JM; PR-1BM/0JM; PR-1BN/0JM; PR-1BT/0JL
(34) 4D0411105DG coil spring / 1 paint mark / 3 paint marks violet green / diesel eng., 6 cylinder; 8 cylinder: PR-1BA/0JM; PR-1BG/0JM; PR-1BM/0JM; PR-1BN/0JM; PR-1BT/0JL
(34) 4D0411105DH coil spring / 1 paint mark / 2 paint marks green grey / 8 cylinder: PR-1BA/0JN; PR-1BG/0JN; PR-1BM/0JN; PR-1BN/0JN; PR-1BT/0JM
(34) 4D0411105DH coil spring / 1 paint mark / 2 paint marks green grey / diesel eng., 6 cylinder; 8 cylinder: PR-1BA/0JN; PR-1BG/0JN; PR-1BM/0JN; PR-1BN/0JN; PR-1BT/0JM
(34) 4D0411105DJ coil spring / 1 paint mark / 3 paint marks green grey / 8 cylinder: PR-1BA/0JP; PR-1BG/0JP; PR-1BM/0JP; PR-1BN/0JP; PR-1BT/0JN
(34) 4D0411105DJ coil spring / 1 paint mark / 3 paint marks green grey / diesel eng., 6 cylinder; 8 cylinder: PR-1BA/0JP; PR-1BG/0JP; PR-1BM/0JP; PR-1BN/0JP; PR-1BT/0JN
(34) 4D0411105DK coil spring / 1 paint mark / 2 paint marks violet blue / 8 cylinder: PR-1BA/0JQ; PR-1BG/0JQ; PR-1BM/0JQ; PR-1BN/0JQ; PR-1BT/0JP
(34) 4D0411105DK coil spring / 1 paint mark / 2 paint marks violet blue / diesel eng., 6 cylinder; 8 cylinder: PR-1BA/0JQ; PR-1BG/0JQ; PR-1BM/0JQ; PR-1BN/0JQ; PR-1BT/0JP
(34) 4D0411105EA coil spring / 1 paint mark / 3 paint marks violet blue / 8 cylinder: PR-1BA/0JR; PR-1BG/0JR; PR-1BM/0JR; PR-1BN/0JR; PR-1BT/0JQ
(34) 4D0411105AR coil spring / for vehicles with sports-type running gear / 1 paint mark / 2 paint marks white yellow / PR-1BD/0JD; PR-1BE/0JD
(34) 4D0411105AS coil spring / for vehicles with sports-type running gear / 1 paint mark / 3 paint marks white yellow / PR-1BD/0JE; PR-1BE/0JE
(34) 4D0411105AT coil spring / for vehicles with sports-type running gear / 1 paint mark / 1 paint mark white green / PR-1BD/0JF; PR-1BE/0JF
(34) 4D0411105BA coil spring / for vehicles with sports-type running gear / 1 paint mark / 2 paint marks white green / PR-1BD/0JG; PR-1BE/0JG
(34) 4D0411105BB coil spring / for vehicles with sports-type running gear / 1 paint mark / 3 paint marks white green / PR-1BD/0JH; PR-1BE/0JH
(34) 4D0411105BC coil spring / for vehicles with sports-type running gear / 1 paint mark / 1 paint mark white silver / PR-1BD/0JJ; PR-1BE/0JJ
(34) 4D0411105BD coil spring / for vehicles with sports-type running gear / 1 paint mark / 2 paint marks white silver / PR-1BD/0JK; PR-1BE/0JK
(34) 4D0411105BE coil spring / for vehicles with sports-type running gear / 1 paint mark / 3 paint marks white silver / PR-1BD/0JL; PR-1BE/0JL
(34) 4D0411105DL coil spring / for vehicles with sports-type running gear / 1 paint mark / 1 paint mark white orange / PR-1BD/0JM; PR-1BE/0JM
(34) 4D0411105DM coil spring / for vehicles with sports-type running gear / 1 paint mark / 2 paint marks white orange / PR-1BD/0JN; PR-1BE/0JN
(34) 4D0411105DN coil spring / for vehicles with sports-type running gear / 1 paint mark / 3 paint marks white orange / PR-1BD/0JP; PR-1BE/0JP
(34) 4D0411105DS coil spring / for vehicles with sports-type running gear / 1 paint mark / 1 paint mark violet green / PR-1BD/0JQ; PR-1BE/0JQ
(34) 4D0411105DT coil spring / for vehicles with sports-type running gear / 1 paint mark / 1 paint mark orange green / PR-1BD/0JR; PR-1BE/0JR
(34) 4D0411105DQ coil spring / for special armoured vehicle / for models with suspension levelling system / 1 paint mark / 3 paint marks front blue white / PR-F4S:0JE, 0JF
there are also a few different front shocks:
28 4D0413031BL shock absorber / marked with: / ** caution! dangerous cargo ** / F >> 4D-Y-020 000 pink / AMX,AQD,APR
(28) 4D0413031CL shock absorber / marked with: / ** caution! dangerous cargo ** / F 4D-1-000 001>> / also use: pink >>4D-Y-020000 8D0 412 066 F / AMX,AQD,APR
(28) 4D0413031BN shock absorber / marked with: / ** caution! dangerous cargo ** / F >> 4D-Y-020 000 grey / PR-1BA,1BG, 1BM,1BN,1BT: AKN,AFB,AKE, AQG,AQH,AQF ARU
(28) 4D0413031CK shock absorber / marked with: / ** caution! dangerous cargo ** / F 4D-1-000 001>> / also use: grey >>4D-Y-020000 8D0 412 066 F / PR-1BA,1BG, 1BM,1BN,1BT: AKN,AFB,AKE, AQG,AQH,AQF, ARU,BCS,AYS, AVP,AUW
(28) 4D0413031CH shock absorber / marked with: / ** caution! dangerous cargo ** light blue / PR-1BA,1BG, 1BM,1BN,1BT; AKF
(28) 4D0413031CE shock absorber / for vehicles with sports-type running gear / marked with: / ** caution! dangerous cargo ** / also use: yellow green >>4D-Y-020000 8D0 412 066 F / PR-1BE: APR,AQD,AMX
(28) 4D0413031CD shock absorber / for vehicles with sports-type running gear / marked with: / ** caution! dangerous cargo ** / also use: light blue >>4D-Y-020000 8D0 412 066 F / PR-1BE,1BD, AKN,AFB,AQG, AKB,AKD,AQF, AKC,ARU,AKE, AQH,AUX,BAX, AUW,AVP,BCS, AYS
(28) 4D0413031CJ shock absorber / marked with: / ** caution! dangerous cargo ** green / PR-1BE; AKF
(28) 4D0413031CM shock absorber / for special armoured vehicle / ** caution! dangerous cargo ** /
Old 9th April 2014, 06:31 PM
Here's the 8 on tarmac (probably not the best quality, but the difference between front and rear is still visible):
And here are the pics from the springs.
Front:
Rear:
The markers seem to be the proper ones for my suspension, after checking Goran's list (thanks for those, mate!). Next week I'll have some work done on the front and will take a look at the springs some more. Dunno, maybe there's something on the front ones to lift it up a bit... what do you guys think, rear springs worn out maybe?
PS
I'll take a pic of a similar one I see regularly for comparison, its arches appear to be equally raised above the wheels.
