Zip I have just done this on My S8. There are 2 methods of fixing the leading edge of the engine undertray.
Method one is via about 6 plastic screw clips which fit through holes in the the front valance ( you may not have any. I didn't) into the mounting points along the leading edge of the under tray. They are call Grip Pins, Lock Washers and Clips. See here items 10, 9 and 8. ![]() Method 2 and the easier method is to fit the panel to the 2 'L' brakets from the radiator using items 12 and 7. The 'L' brakets are fitted with captive nuts. These are the same as are used at the back of the under tray (items 2 and 5). It also clips to the front of the inner wings (2 each side) using items 8, 9 and 10. Part numbers are avalaiable on VagCat.com
