Folks,
This is very annoying. The Nav+ unit in my PF D2 ('98) works perfectly... Apart from the Nav ![]() When I bought the car down in Somerset, the unit was locked, as the battery had been flat. Finally found the code, and tried the Nav- It worked fine, showed current location correctly and when set to navigate to Bristol showed the correct-ish route and distance. I obviously didn't use it then as I know the way! Since then I have needed to use it a couple of times, and the GPS constantly thinks it is somewhere near Poole. It will accept a destination, but obviously won't navigate there- On the "Lat/Lon" display it constantly shows what I believe is a default... ...This is doubly annoying because my little Garmin portable Nav unit has ceased to pick up satellites for some unknown reason ![]() It has the most up-to-date Nav CD in it (2005?) which I think you can get for mine... Help! |
2007 is the most recent disc you can get.....
If it doesn't know where it is, then it either has a GPS aerial fault, or the connection that supplies the speed pulses is faulty. I favour the former as the most likely candidate, and one of the Sat Nav menus will confirm how many satelites are available - If this reads zero then almost certainly the GPS aerial. Cheap replacements ones can be bought for around a tenner, and if nothing else you can plug it in directly to the back of the unit to prove whether its faulty. The aerial on the boot lid has about a meter of length on it, it connects to an extension that runs the full length of the car, and it connects behind the trim behind the Cd changer on the left hand side of the boot. If you do get an aftermarket aerial, and it works in the back of the head unit, plug it into the end of the extension at the boot side and then eliminate the 5m length of coax that runs the lenght of the car. If that also works, then you're looking at a faulty GPS aerial on the boot, which you could replace, or just stick the £10 one on the dashboard tucked in the corner out of the way.... Either way, im sure it wont be difficult to fix, and its almost certainly not a fault with the head unit... ![]()
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
![]() [/quote] My Garmin has the same problem. I think this is caused by the S8's slightly mirrored glass making the interior of the car somewhat impervious to radio signals. Not enough to block mobiles, but enough the leave my Garmin struggling. Sounds like your glass may be mirrored too. A simple test is to try your Garmin outside, then inside the car |
Ian,
Thanks for another informative reply ![]() I like the idea of tucking an aftermarket one away somewhere- The OEM one is colour coded! Are they a universal fitment- IE what shape/type of connector do I need? |
Figure11 has done a chunk of preliminary work on this.
Given the size of the unit on the boot and the size of a modern GPS mouse, you should be able to sneak the guts into the original space, or even at the bottom of the windscreen if you don't have the athermic glass and then just run the cable along. Can't remember which connector it is, but you can get adapters pretty cheap on t'interwebs.
http://cgi.ebay.co.uk/GPS-Antenna-SM...d=p3286.c0.m14 Although I'm 99% sure we have a brand new one in stock, and could do it at a similar price....
Thanks all, but I'm STILL having problems... Bought an aftermarket aerial from the good folks at A8parts which turned out to be the wrong size, have a new one now (Ta muchly!) and it still doesn't want to work... Plugged it directly into the back of the Nav+ unit and have variously dangled the antenna on the roof, outside the car and in the windscreen, and still doesn't pick up satellites.
Since I've plugged it in, the available satellites display has gone from around 25/27 to 30, however at best it only shows 1 satellite as "receiving"- Which obviously won't work.. Help! Should I plug it in at the boot instead? PS- It's actually a RNS-C unit ![]() |
My sat nav seems to have developed the same fault. I tried to use it today and it can't get a fix on my location. Had a look at the GPS Viewer menu and it says Available 30 Recieve 0.
Everything worked fine last time i used it a couple of weeks ago. What connections are there from the receiver? Is there a connection within the boot lid which might have worked loose or does the cable run continuously to the Nav unit? |
If you have got the right aerial (the SMB connector clicks on quite re-assuringly, you'd know if it was wrong) plugged directly into the rear of the unit, and it is in good line of sight of satelites (pop it on the roof for the test, not inside the car, and dont be in a built up area if possible), and you get 0 satelites received the only logical answer is for the Nav unit to be faulty..... ![]() Edit - Given that GPS technology is 4 dimensional, and has to fix 'time' before it can get a fix on position, it can take a good few minutes to get a fix. Dont be spoilt by little handheld devices that get a fix in half a minute, you need to show some real patience here and I'd give it a good 5 mins myself before I wrote it off...
