Old 13th April 2014, 11:21 PM
Is that a bloody great crack on photo 11
Fuuuuuuuuuuuuuuuuuuu*k, I think u r bloody right
Old 14th April 2014, 12:36 AM
As well as the crack, the bushes appear shot too. If there is that much surface cracking then the rubber has lost all its flexibility.
Old 14th April 2014, 06:36 AM
Might also be worth checking the track rod ends, I had them replaced on the D2 due to strange sounds when turning which was originally put down to the steering. They looked fine from the outside but the ball joints had seen better days.
Old 14th April 2014, 07:48 AM
The originals are TRW, and the aftermarket ones have the part number cast, but the VW/Audi logo ground off.
Old 14th April 2014, 07:49 AM
Not sure if it's cracked or just a sharp shadow caused by the flash, but worth checking.
The bushes are definitely shot though
Old 14th April 2014, 08:05 AM
Great stuff guys.
And will check that crack shortly as its very interesting.
I'll go for TRW then
One question which still does bother me. Have you listen the sound guys? If yes, is that sort of sound you would expect from bushes when they are cracked as mine BUT ONLY when they get hot?????
Is thats what I need??
http://www.mister-auto.co.uk/en/susp...61JTC1139.html
http://www.mister-auto.co.uk/en/susp...61JTC1138.html
Plus, how hard is to change them other than having car at the right height when doing the bolts up??
Does car need to be jacked up or on the ramp??
I heard that some of them long bolts can be a real pain.
Old 14th April 2014, 09:06 AM
I think I will have to replace all 4 upper ones, will try to jack it up today and take a proper look.
Old 14th April 2014, 10:14 AM
Marcin, listening to the sound its exactly the same as my old D2 and the sound turned out to the be track rods ends as I mentioned a couple of posts ago. The bush in photo 11 is dead but I would have expected a clonking sound from that rather than the audible groan.
Old 14th April 2014, 10:46 AM
The noise sounds like something dry getting rotated, mountings at top of strut possibly? Either way the arms need doing as the bushes are shot and when your in there pulling it all apart check everything else.
Old 14th April 2014, 03:53 PM
Sound is pretty much like dry ball joint. Try to clean them up on outside so that dirt does not get in, peel back rubber boot a bit, spray some grease/oil in there and see if noise goes away. If it does you know where it's coming from but to sort them out properly would need to clean old grease out and pack with new grease if there is no wear in them or replace if too much wear.
Bushes does not look good but I would not say that they are shot. As long as there is no excessive movement they should be fine. 2-3 year old bushes can look like that but last for another 7 years before needing replacement.
