Old 12th May 2014, 03:04 PM
Extended aluminium pack is the shiny surrounds on the vents, MMI, etc. And then there are the aluminium trim pieces for the door/dash instead of the grey plastic which are seperate.
Old 12th May 2014, 08:37 PM
Was there a...half extended aluminium pack??? I know it sounds weird, but I've got one, around vents, mmi, ash trays, ac, etc, but none on the door trims, the only aluminium part is the actual handle
Old 13th May 2014, 06:48 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
That's why I asked.
I got the same.
I've seen some with chrome bits on the door pockets.
[center]
06 3.0TDI Quattro:
Options:
Old 13th May 2014, 07:06 AM
The aluminium door trim bits were a separate pack (though standard on W12 I think). Not sure about the chrome on door pockets.
Old 13th May 2014, 07:23 AM
ScottD3's Avatar
When you Ally door trims you mean these yeah?
Look at the door pockets.
Chrome bits.
[center]
06 3.0TDI Quattro:
Options:
Old 13th May 2014, 07:49 AM
Cheers guys
I don't have the door pocket trims, and they look nice I have to say.
Old 13th May 2014, 07:55 AM
ScottD3's Avatar
I'd like a set of them.
Off to ETKA later I think.
[center]
06 3.0TDI Quattro:
Options:
Old 13th May 2014, 07:58 AM
I think the door pocket trims cam on the second facelift as that is all I have seen them on >2008. Anyone confirm?
I have the aluminium bits on the vents, headlight switch etc... but the inch wide strip across the dash is painted metallic grey, I would be interested in replacing this, is it real aluminium or a better aluminium like finish? I wonder if it could be wrapped?
Old 13th May 2014, 08:07 AM
ScottD3's Avatar
When you remove the door trims you can strip them down into 3 individual parts.
So I'd assume you can.
Same as snapdragon really not sure on changing the lower trim bits.
I would like the door pockets in chrome.
This my rear door.
That lower section in that painted grey is nice. Not sure if real alloy would be to much?
[center]
06 3.0TDI Quattro:
Options:
Old 13th May 2014, 08:32 AM
Hmmmm, I don't have a chrome bit around the light switch
Everywhere else apart door pockets, just not there now.
When I did carbon wrap on my car few months back I instantly thought about wrapping that silver bar all round. It's not chrome, just painted silver.
Re-spray is one option as it looks a bit older just below a new carbon wrap, but I thought about carbon wrap as well, just different colour.
Instantly I thought, and don't judge me here as its difficult to say without having a finished product, about white or silver carbon. White could look interesting in contrast with black just above it, but .... it may look completely ****
The tricky part to wrap is just the center part on the dash, just where where mmi screen and parking aid switches are, around them there is tiny groove which could be a problem.
A heat gun (which I use anyway) and my selection of window tinting tools I think would do the job, but can't be sure until I try.
When I did my carbon supplier I used had no other colours, but when I checked his page they do now same quality and design carbon in white, silver, even yellow etc so I may try at some point.
