Is the tranny module not under the carpets on these cars and as they are known for getting you feet wet thats where I would be looking first.
Del ![]() |
Its funny you should say that but a few hours before we had an absolute monsoon of rain. I'll go and check.
From memory I think it's in the ECU box under the bonnet, tucked away under the engine ECU. Andrew will know as he's been ferreting in that area in the past looking for evidence of leaks.
Is the valve body loom accessible without removing the sump from the box? I know there's a plug for the F125 switch but not sure how many others are on the outside of the box. If it's driving fine it does suggest it's probably just gremlins in the machine/a small electrical fault from the wet winter we've had. I'd clear and see if they return before worrying too much. Airbag is probably a dodgy connection too
The car was left for two months whilst I was away Feb/mar and though my son started it and moved it, the battery was flat on one occasion - probably from the passnger door microswitch which sometines keeps the lights on.
thats good news then, may just by the connection to the gearbox gutting green and furry
Del ![]() |
I'll clear the codes and take it out for a run, then and see what happens. and also check the drains
Well, the first thing i did was pull the plug to F125 and inspect it. It all seemed dry and no corrosion. Checked the scuttle drains and cleared out debris (its spring and the car was covered with blossom and pollen and the scuttles were too). There was no build of water in the scuttle but it wasnt flowing as freely as it should so brushed /vacuumed all the crap out till free flowing.
I removed the ECU cover and all was dry and OK in there with the exception of an indication of slight water ingress in the back right hand corner where there was a dirty but dry "smear" . What was noticeable on closer inspection was a tremendous build up of leaf debris at the back where the lugs on the cover engage with the case. There is an "upstand" in that area just perfect for catching debris and trapping it against the joint! Its obviously be doing that for years judging by the white deposits on the plastic. So, carefully vacuumed that up, greased the seal and put the cover back on. Cleared all codes now and will take the car out soon for a run and then scan again. Hopefully all will be good. Fingers crossed.
I had a lot of build up in there too David, although all wet. It's easier to remove when the scuttle panel is off.
Hopefully it's just a few gremlins after being sat for a while damp. Good run with the aircon on will help dry out the inside.
