Old 28th May 2014, 08:44 PM
Reffro Reffro is offline
Bellows and linkage for your variable length inlet manifold.
Sorry to say but if the linkage has gone, its likely that the manifold flaps are seized too.
Old 28th May 2014, 08:51 PM
Easily tested by moving the arm by hand.
Old 28th May 2014, 09:57 PM
Just looking at the pictures again I'm confused.
Those broken ends don't seem to meet and are at the wrong angles.
Yet there's a component to the right (as you look at it) that looks familiar and is just like the actuator arm on my manifold flaps.
Is it, when not broken, some sort of Z-link where a single vacuum actuator pulls on one link to move one flap then there's a link from that back across (to under the actuator) to the arm for the second flap?
On the D2 S8 the flaps both have their own actuator, maybe on the D3 3.7 they work together?
Either way, look for more broken bits....
Round here, that looks like the arm that moves a manifold flap, note the chunky return spring:
Old 28th May 2014, 10:44 PM
There are 2 links on the 3.7 and other A8's and they are longer than the pair on the S8's they break because they are designed to if the manifold flaps are seized or sticking. If you swap them for some of the metal ones I have seen then be careful as you could end up with more damage to the manifold flaps if they decided to seize up again. Mine stuck on and were discovered when Reffro and myself were checking our respective cars at AITP a couple of years ago. In the end I had James (Mkoneman) fix them by cleaning the pivots using the remedy recommended on Audipages HERE
What you WILL notice when this is done is a difference in either bottom,end or top end responsiveness as the flaps will be stuck either open or closed and that will affect one end of the performance range or the other.
Old 29th May 2014, 07:40 AM
No longer.
Looking yet again I can see the second vacuum bellows down and to the right.
Old 29th May 2014, 02:14 PM
Cheers Ollie for adding another job to already packed ''To Do before Annual Meet''
Both broken.
Spoke to my Audi guys, a repair kit, upgraded one inc. some other bits not just the links, £211 from Audi,
I looked at the ones from the link earlier and they look way much better value and quality, 125 dollars inc shipping thats £75 !!!!!!
I wonder if they would arrive by next Friday??
No info about delivery times on their website
Old 29th May 2014, 05:04 PM
mannyo mannyo is offline
Make sure the flaps themselves are not stuck before replacing the broken plastic parts. You should be able to move the plastic arms by hand against the spring pressure, and they should return smoothly as well. Mine are stuck fast, so replacing the plastic arms will make no difference and could make things a whole lot worse.
Manny
Past
Old 29th May 2014, 05:15 PM
Good news for me, both flaps are moving so they are not seized.
I wont be buying ridiculously expensive plastic ones from Audi anyway, I'll order a set of these http://www.gruvenparts.com/audi-vw-4...-linkage-arms/
I've tried all day calling the shop to ask how long will the shipping take but no answer. I emailed them 2min ago so now wait an see. I'll be getting them tonight anyway, I just really really hope that for 35dollars shipping charge they will arrive by next Friday
Old 29th May 2014, 05:43 AM
Yep, both mine are broken because the flaps are seized solid, car feels no slowe than my old D2 which had working flaps.
Manny
Past
