Old 31st May 2014, 09:25 PM
Somerandomguy's Avatar
Default Component protection
Great write up, thanks - I have started fitting mine and have got most of the parts. Unfortunately, on my boot lid, I had to cut out a small piece where the camera sits with the dremmel. I assume later model have a cut out instead.
As I already have cable tubes on both sides of the boot, I decided to make my own loom and Im glad I did as there was no chance of getting the insides of the fakra cable down there. As it was I spent about an hour feeding the cables through using loads of silicone lube to encourage the cables through!
Did you get component protection on the gateway? If so, what was affected? Im wondering what will happen if I cant get CP removed for a couple of weeks...
