Old 16th June 2014, 01:58 PM
SilverS8 SilverS8 is offline
Then we have found the link between fuse 5 and 6 i guess.
tried removing the panel around the sunroof switch but afraid i'll break something. Anyone know how this is done?
will try to unplug the thing.
Also, does the CL have any relays? might be an idea to remove if it excist.
Thanks for all help so far
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 16th June 2014, 02:26 PM
I guess that a "message" is sent between the central locking module and the sunroof module telling it to shut the sunroof. But has the sunroof been open? If its already shut why would it blow? Does it blow when when you try to open/ shut the roof using the normal control switch? (do you use a sunroof in Norway )
Old 16th June 2014, 03:30 PM
No, sunroof is just for display purposes
The sunroof was closed when this happened. I just pressed the keyfob thingie to lock the doors and nothing happened. Then tried manually locking it with the key but only drivers side would lock..
The fuse blows the second do the following
-Press the keyfob to lock or unlock
-pressing down the doorknob on driver side.
I have had a CL error message in vag-com for quite a while regarding the CL pump running a bit to long(possible leak) but it has despite the fault code been working flawless..
2000 Silver S8
Old 17th June 2014, 07:25 AM
mikes2 mikes2 is offline
It could well be a few broken wires shorting where the door joins the wing - you'll need to pull back the rubber boot to check them
2002 3.7 quattro sport (SOLD)
