Old 17th June 2014, 08:30 AM
Sorry bout the late reply M-A8.
In to HVAC and just add 2 to what ever coding you got.
Mine was 49 on the end, so it went up to 52.
Turn the ignition off and on and it's there. Sorted.
The engine don't start. The little diesel burning under the air box fires up. You can hear it humming.
That's for the Aux heat.
It will warm up the coolant, pump it round the engine and heater matrix. It's not boiling hot like the engine does, but enough to melt ice and take the chill out of air on the cold mornings.
I set the aux fan up to turn on for 45 minutes before I finished work and to run for 45 minutes. The cabin was cooler and it never took any bars from the battery monitor.
Happy with this little mod.
Great stuff, thanks for that Scott
Will update you as soon is done...if it works with mine. Can't see why it wouldn't as the module I'm connecting to is Auto HVAC not HVAC, or all off them are called Auto HVAC.
It's probably one of those function which is fitted as standard, but disabled if you don't pay for it as it's classified as extras
Any luck with finding a remote for it Scott??
Old 17th June 2014, 08:32 AM
...or or or, how about a GSM module which would allow you to do it all from your phone, how cool would that be
Old 17th June 2014, 08:34 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Not very OEM though is it?
[center]
06 3.0TDI Quattro:
Options:
Old 17th June 2014, 08:37 AM
Ooooh, come ooooon. It's better than a remote, it would allow you to do it from bed and OEM not, hmmm?
As long it's not visible it's fine
PS, just posted something you may find interesting in your AC thread
Old 17th June 2014, 08:41 AM
ScottD3's Avatar
reminds me of the old Clifford and Toad alarms where they had all this extra bits of kit you could plug.
[center]
06 3.0TDI Quattro:
Options:
Old 17th June 2014, 08:49 AM
I think I found it
http://www.ebay.co.uk/itm/Webasto-Te...item1c4110c15e
http://www.ebay.co.uk/itm/Webasto-Re...item3390733da7
Old 17th June 2014, 08:53 AM
Sourced from there and you may want to read it as it looks like you may need extra bits Scott.
http://www.tyresmoke.net/forum/topic...to-your-a8-d3/
Old 17th June 2014, 09:00 AM
ScottD3's Avatar
That's for the remote start and such.
I'm not that bothered about that really.
Reading that guide and what Snapdragon said, I'll need the recirculating pump to stop it from overheating.
[center]
06 3.0TDI Quattro:
Options:
