Old 20th June 2014, 08:31 AM
Hi David
Hi Marcin
I know his forum name might suggest his real name is David, but it's Guy! As in the number plate!
But I'm sure he'll not mind what you call him with the all the help you're giving!
Old 20th June 2014, 02:45 PM
It would not let me log in using my current car log in ? It seems to only accept the log in of the donor car ? ....
Hi Guy.
Compatibility issue as mentioned before??
Could you post the year of your car and part number of the module you've fitted and I will check if it's compatible with your car.
LWB A8 4.2 Petrol it's all I know so just the year and that should be enough.
Do you know if the part number of the donor's module is exactly same as the one from your car??
PS. Cheers Jim for clarifying Guy's/David's name
Old 21st June 2014, 11:36 AM
Ok yes its a 2003 D3 .. and hear is a whole host od modules I can get hold of .. il have to go and pick the correct one from london.
This first one is the module I removed first
The rest are what they have in stock ....
the one I fitted ended in H44 ...and lets me log in as a W12 but will only accept and store W12 settings ... and all I get is a dash board like a xmas tree
foolishly I did not take a photo of the part I fitted I just assumed it would work...
ps im very very very grateful for all the help im at a loose end with this
Old 21st June 2014, 11:56 AM
No problemo guy
I'm sure we will get to the bottom of this.
I'm going out now for about 2-3 hours and will jump on it as soon I'm back.
Are you far from London?
Are they not prepared to ship it to you??
If not where are they Base coz if close to me I could pick it up and ship it over to you via ups next day??
Old 21st June 2014, 12:12 PM
I pulled that quickly before leaving...
Old 21st June 2014, 12:14 PM
Thats very kind of you too offer its in luton im not sure where you are based? I wouldnt want to put you out of your way im great full for the help so far
Old 21st June 2014, 12:47 PM
That's for V6 diesels and V8 petrols.
V8 diesels and 10 and 12 cylinder petrols have a bit more choice.
Old 21st June 2014, 01:19 PM
Ok so im plugged into the car this is what its saying
and
And
Old 21st June 2014, 01:21 PM
This is what the SwB W12 said just for reference. . Its E not a C
Old 21st June 2014, 01:31 PM
From your picture am I correct in saying that a BD should work fine is that 8 cylinder + diesel too ?
