Old 23rd June 2014, 06:31 PM
Bottom number is the Software version NOT the part number, if you look middle 3 numbers are different, 910 instead of 614.
Old 23rd June 2014, 06:36 PM
Your software should be 4E0 910 517 A (VAG Number)
If you go to advance ID you should get the part number (BD for example) which is 4E0 614 517 x or xx
Old 23rd June 2014, 06:46 PM
Yes and indeed it had come up in advanced id as a BD unit
4E0 614 517 BD
4E0 910 517 C
Old 23rd June 2014, 06:48 PM
Im struggling hear ...4 units later and im no closer to home ..
It let me log in under a LWB W12 .. re coded it and now its only taking coding .0007637 and thats a W12 .. if I try my lwb 4.2 i get an error message saying out of range
Old 23rd June 2014, 07:01 PM
Well, yeah, it's a bit of a struggle due to wrong PNs being installed, but heads up, we will get there
Hold on, so you logged in to W12 LWB, coded it so what's wrong with it??
Do you get any errors??
Any lights on the dash??
So it does accept coding or not if you said you recoded it??
Old 23rd June 2014, 07:04 PM
Out of range means usually that unit is dead so it doesn't matter even if its the correct PN or not, it will say same thing for any dead unit
Old 23rd June 2014, 07:08 PM
It allowed me to log in as a W12 it then accepted coding for a W12 LWB .. and now stores the soft ware ..but still have lota of lights on the dash board
Old 23rd June 2014, 07:20 PM
That could mean just that unit which you've installed is fully working, but not compatible ??? Unless needs adopting? test drive? or other bits adopting?
I'm not an expert, but in my opinion non of the above, it's just the wrong part number in my opinion.
From my experience I was able to code modules (coding accepted) even if coding was wrong for the spec of my car, but it wasn't functioning properly.
Old 23rd June 2014, 07:42 PM
I agree ... back to hunting for a unit with E or CC then ..
Hope I can take the units back and swap getting a few hear now
Old 23rd June 2014, 07:50 PM
Here is one for fair money, offer them 150quid, they may accept or counteroffer you 175 whichy is still a good price
You can use E, L, A, C or CC
