Originally Posted by audifin
Replying this old thread:I was able to fix mine with solder flux paste following instructions from these youtube links:
https://www.youtube.com/watch?v=-G-OedMyf8o
https://www.youtube.com/watch?v=PG1v9xDpDH4
Basically if the motor is spinning but the boot lid is not moving then the clutch inside the motor is slipping. You can fix that by applying some solder flux paste on the clutch. Try applying as thinly as you can, I put too much first and had to disassemble the motor again because the clutch got totally stuck  Anyway it works like a charm now and the total cost was £1.70, so I'm well happy
A little update: The solder paste works for a while, but then melts away, especially in this hot weather!!
However, found this link on google and decided to try it:
http://www.dognmonkey.com/audi/how-t...-audi-a8l.html
Bought "Violin Rosin" off eBay for £1.69 delivered, scraped it with a knife into dust/crystals. Cleaned all the old soldering paste off the clutch and replaced it with small amount of this "dust", and it worked perfectly first time. Time will tell how long it will last, but I have gut feeling it will last much longer than the soldering paste.
